8" rim - widest tire?
00transamnh View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 00transamnh Quote  Post ReplyReply Direct Link To This Post Topic: 8" rim - widest tire?
    Posted: 17 Nov 2016 at 9:28am
Lots of tire talk on this forum but I cant seem to find exactly what Im looking for.
What is the widest tire that will fit on an 8" Model B rear rim? 9.5-24?
Edited by 00transamnh - 17 Nov 2016 at 12:36pm
cpg View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cpg Quote  Post ReplyReply Direct Link To This Post Posted: 17 Nov 2016 at 9:56am
My brother has 11.2-24 tires on his B and they work fine, don't look really rolled out or anything. When I put my B together it had an old set of 13-24 Firestone connected tread tires which I guess today would be close to a 14.9-24 size. I took them off because the side wall rotted and ripped and it sat way high in the back and they were pretty round from being squeezed by the rim. So the biggest that will physically fit; at least a 14.9-24. Biggest I would recommend for a good fit and traction; 11.2-24. Mine now has 9.5-24 which are fine but they don't bite as good as the 11.2's on my brothers and his will obviously go a bit faster.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 00transamnh Quote  Post ReplyReply Direct Link To This Post Posted: 17 Nov 2016 at 12:35pm
Anyone have a picture of a set of 11.2's on a B? Also CPG, i assume those are on 8" rims? I beleive the Bs came in 8,9, and 10" rims. Need to verify they will fit my 8's
cpg View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cpg Quote  Post ReplyReply Direct Link To This Post Posted: 17 Nov 2016 at 1:00pm
I guess I never measured which it had, never really paid attention to them having different width rims, I thought there was only one width on the B's. I can probably find a pic of it but I don't know the rim width. I can measure my rims and show you what a 9.5 looks like on that rim.
Tony.Or View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tony.Or Quote  Post ReplyReply Direct Link To This Post Posted: 17 Nov 2016 at 4:28pm
 to be  correct  9.5  tire  on  8"  rim.   11.2  tire on 10"  rim..   12.4  tire on  11"  rim.. Tony
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 17 Nov 2016 at 9:08pm
In the days when the Bs were new tire widths were the rim widths and the tire widest part was wider. In the 50s tire designations changed to the width being the widest width of the tire wider than the rim widths. There are some comparisons on the Miller Tire web site.
Titan/Goodyear and other tire makers offer an Ag Tire handbook, on line, used to be on paper and towards the back it shows the approved rims for each tire size. Generally there is a preferred rim and a couple different from the preferred rim but acceptable.
Last I checked, google Goodyear Ag Tire Handbook, and it will come up.
Gerald J.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 00transamnh Quote  Post ReplyReply Direct Link To This Post Posted: 18 Nov 2016 at 6:35am
The goodyear catalog only states "recommended width," which basically states 10" rim = 11.2-24 and a 8" = 9.5-24. I will most likely go with a 9.5-24 but would still like to know if anyone has tried to go wider on an 8" rim.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 18 Nov 2016 at 3:27pm
Search for the table "Approved Rim Contours" it shows three or four rims for most bias ply tractor drive tires. The basic tire data shows only the recommended rim. The Approve Rims table shows a column for recommended rims and another column of approved rims.
Gerald J.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 00transamnh Quote  Post ReplyReply Direct Link To This Post Posted: 18 Nov 2016 at 5:57pm
Awesome, thanks Gerald.
For future reference:
http://www.titanstore.com/pdf/Approved%20Rim%20Contours-03-14.pdf
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 18 Nov 2016 at 9:17pm
If you patiently search "recommended" you will eventually turn up a few paragraphs on the effects of mismatching rim widths and tire widths.
Gerald J.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 22 Nov 2016 at 8:12am
Gerald J.
I did just as you said Gerald and came up with this:
NOTICE
Goodyear has sold its farm tire business in the United States and Canada to Titan Tire Corporation.
For information on Goodyear branded farm tires in the United States and Canada, please click the link below.
www.titan-intl.com
I didn't even know that........ WHERE have I been!??
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 22 Nov 2016 at 8:31am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 22 Nov 2016 at 10:14am
Titan bought Goodyear four or five years ago. Titan bought another ag tire maker decades ago.
Gerald J.
