D17 power steering fluid
PaulP View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulP Quote  Post ReplyReply Direct Link To This Post Topic: D17 power steering fluid
    Posted: 16 Nov 2016 at 3:57pm
My Son is restoring a 1961 D17, have heard conflicting answers for type of fluid used in power steering reservoir in front of rad? We don't have manual, suggestions would be appreciated,
Thanks
Paul
Orange Blood View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orange Blood Quote  Post ReplyReply Direct Link To This Post Posted: 16 Nov 2016 at 4:20pm
Seems the general consensus around here is Universal Tractor Fluid.  I run ATF, but I've been mildly chastised for it, never had any problems.
Still in use:
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 16 Nov 2016 at 4:52pm
My Dad bought a brand new D-17 IV and it had Dexron from the Factory. It continued to have Dexron for several years and was always dirty around the front support from that water like oil seeping thru every gasket and seal there was. Changed to Universal Hydraulic oil and that seepage all stopped. Either will work and when you already have hydraulic fluid, why not keep it simple ??
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulP Quote  Post ReplyReply Direct Link To This Post Posted: 16 Nov 2016 at 7:03pm
Thanks much, will give it a shot!
Dswall View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dswall Quote  Post ReplyReply Direct Link To This Post Posted: 16 Nov 2016 at 8:32pm
I put in hytrans once and it kept foaming. Old AC mechanic told me use ATF and been using it ever since. Works great
Edited by Dswall - 16 Nov 2016 at 8:34pm
Dustin in CA
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 16 Nov 2016 at 8:48pm
I think the spec was 5w20...
Post Options Post Options   Thanks (0) Thanks(0)   Quote allischalmerguy Quote  Post ReplyReply Direct Link To This Post Posted: 18 Nov 2016 at 1:44pm
What ATF do you use? Dextron or ford,,,,ect?
This page was generated in 0.054 seconds.
