Loader Cylinder Question
Fuzzy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fuzzy Quote  Post ReplyReply Direct Link To This Post Topic: Loader Cylinder Question
    Posted: 15 Nov 2016 at 9:32pm
I am trying to rebuild my 400 series lift cylinders and I can't figure out how to get the retaining nut off. I don't want to beat the crap outta the nut with a punch and destroy it, but I also don't know what the correct tool would be. All of the gland nut wrenches I've seen have round pegs and mine has two rectangular slots. What's the correct tool, and where do I get one?!?
Edited by Fuzzy - 16 Nov 2016 at 9:12am
Clay View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Clay Quote  Post ReplyReply Direct Link To This Post Posted: 16 Nov 2016 at 11:09am
Easy to make the wrench.
Take a piece of plate and cut a half circle to fit the polish rod.
Two pieces of key stock. Weld the key stock to the half circle plate.
Weld an old worn out  (long) wrench to the plate.
Now you have your own cylinder gland nut wrench.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 16 Nov 2016 at 11:33am
A-C had a special wrench made for just that kind of cylinder. Good luck grinding keystock down that thin and having the strength the factory tool had.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fuzzy Quote  Post ReplyReply Direct Link To This Post Posted: 16 Nov 2016 at 3:49pm
I don't have the tools/ability to weld up my own wrench anyway.
Anywhere I could find a wrench like that?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 16 Nov 2016 at 4:00pm
I made one with bar stock. I drilled and tapped two holes at correct spacing. Then screwed in two grade 8 bolts. Flipped it over and machined the flats on bolts. Works real well. One of the perks  of having a machine shop. Tracy
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 16 Nov 2016 at 6:22pm
Don't know if you could crank out a half dozen or so and be able to sell them for $50 or not?? Probably some would think that's too much anyway.
LeonR2013 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LeonR2013 Quote  Post ReplyReply Direct Link To This Post Posted: 16 Nov 2016 at 6:28pm
Do you have a torch? If you do heat it real good and you should be able to tap it out with a punch. If it's already leaking you ain't goin' to hurt anything.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 16 Nov 2016 at 7:24pm
Dr Allis, you are so right. Some people don't consider the time required to make up special tools. In the long run it saves the user much time and effort. Tracy
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fuzzy Quote  Post ReplyReply Direct Link To This Post Posted: 20 Nov 2016 at 10:02am
I don't have a torch and I dont have a machine shop. I was hoping I could just buy the tool. $50 is very reasonable.
Guess I'll take it in to the hydraulic shop and grab my ankles...
Clay View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Clay Quote  Post ReplyReply Direct Link To This Post Posted: 20 Nov 2016 at 10:21am
I forgot, my dad made one similar to the one Tracy mentioned.
Daddy made it out of an adjustable jaw wrench with the pins welded to the jaws.
Dave (NE) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave (NE) Quote  Post ReplyReply Direct Link To This Post Posted: 20 Nov 2016 at 11:07am
Are you talking about needing a spanner wrench? You can get them at TSC. Otherwise, I simply made one with a couple pieces of flat steel I had left over from a garage door hardware, which I crossed over each other in the middle. Bolted them together. Then put bolts in the ends the size of the holes in the cylinder I needed them to fit.
Here is a picture of the spanner wrench I made (black bars) and some that Gatz had made (nice looking orange ones) and given to me.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave (NE) Quote  Post ReplyReply Direct Link To This Post Posted: 20 Nov 2016 at 11:09am
Oops, picture here I hope.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fuzzy Quote  Post ReplyReply Direct Link To This Post Posted: 20 Nov 2016 at 1:02pm
Well, I took the same hardware off my garage door and tried to make that same setup, but it didnt work because the bars are too wide. The piston is 1.5 in. and the rectangular slots are 1 7/8in apart. So I tried to make a tool out of thinner stock that I had laying around and ground down some grade 8 bolts to fit the slots, but the bars just bent when i put pressure on them.
I'd love to see the AC tool that is designed for this- I dont know how you build a wrench that is wide enough to span the 1.5 in piston, but narrow enough to fit the narrow slots and strong enough to break the whole thing loose.
Edited by Fuzzy - 20 Nov 2016 at 1:03pm
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 20 Nov 2016 at 7:23pm
in your case i would go to a local fab shop with your cylinders and have them biuld a wrench for you , then use it to break them loose in case some heat is needed and test the quality of the wrench you are buying.  then you will be on your way to finish the job your self             sometimes mild steel just wont cut it,so  i keep a r plate around and old cutting  edges  for things that i need hard springy steel for mostly when i have to make a tool
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave (NE) Quote  Post ReplyReply Direct Link To This Post Posted: 20 Nov 2016 at 8:13pm
[QUOTE=Fuzzy] Well, I took the same hardware off my garage door and tried to make that same setup, but it didnt work because the bars are too wide. The piston is 1.5 in. and the rectangular slots are 1 7/8in apart. So I tried to make a tool out of thinner stock that I had laying around and ground down some grade 8 bolts to fit the slots, but the bars just bent when i put pressure on them.
Sorry, thought I had a great idea, as it worked for me on the D17 IV lift arm cylinders I had to redo. And it is even adjustable! Good luck with your fabrication project. Dave
Tbone95 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 21 Nov 2016 at 6:38am
Sorry about your dilemma. Christmas is coming, I strongly suggest asking Santa for a torch. Gotta be the #1 tool required after your basic wrench set!
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 21 Nov 2016 at 1:01pm
9 times outa 10 heat is your friend...
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 21 Nov 2016 at 4:36pm
DANG Steve, you're a poet!  BUT, I agree........
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 21 Nov 2016 at 7:41pm
Even if you have the "factory wrench" I'm betting some heat will be required. I did a Power steering cylinder last winter. Wrecked a store bought wrench, then built my own heavy duty one and still couldn't budge it even after heating some.
 I ended up taking the wrench and cylinder to the local machine-welding shop and with a rose bud torch on it and a 3 foot cheater on the wrench, we got it to break loose.
