All Crop Drill linkage
PBSoMd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote PBSoMd Quote  Post ReplyReply Direct Link To This Post Topic: All Crop Drill linkage
    Posted: 15 Nov 2016 at 5:30pm
Looking for a pic of the clutch linkage for a 9 x 7 All Crop Drill if anyone has one. Trying to figure how the chain was mounted to disengage the clutch when raised. Pic out of a manual will work also.
Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 15 Nov 2016 at 5:37pm
Mine is up against a wall on the left side.  The chain to disengage it is attached to the hook that the heavy chain carries it when lowered.
Post Options Post Options   Thanks (0) Thanks(0)   Quote PBSoMd Quote  Post ReplyReply Direct Link To This Post Posted: 15 Nov 2016 at 5:53pm
Thanks Paul, mine is a pull type, looks a little different but I think should work basically the same. This helps!
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 15 Nov 2016 at 5:57pm
I might have something clearer to look at if the parts book shows what you want. is yours hydraulic or rope lift?
Post Options Post Options   Thanks (0) Thanks(0)   Quote PBSoMd Quote  Post ReplyReply Direct Link To This Post Posted: 15 Nov 2016 at 6:00pm
Hydraulic
Thanks
