Plowing with my B
R.W View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote R.W Quote  Post ReplyReply Direct Link To This Post Topic: Plowing with my B
    Posted: 15 Nov 2016 at 10:04am
Did some plowing with my B the other day. Did a pretty good job with my old 2-14 trip plow. I couldn't run it quite as deep as I'd like due to no weights or fluid, but all in all it did well.
[TUBE]DPT-sap1uPQ[/TUBE]
Edited by R.W - 15 Nov 2016 at 11:39am
Acdiesel View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Acdiesel Quote  Post ReplyReply Direct Link To This Post Posted: 15 Nov 2016 at 10:41am
the picture looks almost like a painting.
nice little set-up.
dan
D19 Diesel,D17 Diesel SER.3
2-D14, 2-D15 SER.II WF/NF
D15 SER.2 DIESEL
D12 SER.I, D10 Ser.II
2-720'S D21 Ser. II
Gmc,caterpillar
Dick L View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 15 Nov 2016 at 11:10am
Great picture!
tadams(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tadams(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 15 Nov 2016 at 1:51pm
Look at that black dirt
Randy WI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Randy WI Quote  Post ReplyReply Direct Link To This Post Posted: 15 Nov 2016 at 2:50pm
Doggone now you done it I have been looking for a 1 bottom plow for my B by the way it looks just like yours. Now I'll have to start looking for a 2 bottom trailer. Looks to handle it well nice job. Randy
Dave(inMA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave(inMA) Quote  Post ReplyReply Direct Link To This Post Posted: 15 Nov 2016 at 3:47pm
Sure looks like nice soil! Really enjoyed watching that B working.
WC, CA, D14, WD45
CrestonM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 15 Nov 2016 at 4:17pm
I like my 2-12 Oliver. I used to plow all the time in red clay with no weights and the plow buried. Actually...I do have a belly sickle mower on it, so that adds weight to the middle. I recently put rear wheel weights and it really goes now!
If you have normal to heavy soil, I'd stick with a 2-12. 2-14 con sometimes be a bit much. JMHO
Lon(MN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lon(MN) Quote  Post ReplyReply Direct Link To This Post Posted: 15 Nov 2016 at 4:51pm
Looking good
Edited by Lon(MN) - 16 Nov 2016 at 6:45am
Hubnut View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hubnut Quote  Post ReplyReply Direct Link To This Post Posted: 15 Nov 2016 at 5:45pm
Wow.  I loved the video and picture.  It was really neat to see a B plowing.  Looks like she grunted a little, but handled it well.  Thank you for posting!
1940 B "Lucy"
1941 B w/ Woods L59 "Flavia"
1942 B w/ finish mower "Dick"
1941 C w/ 3-point "Maggie"
1947 C SFW w/ L306 "Trixie"
1972 314H
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 15 Nov 2016 at 5:46pm
Ok...Question...what's that flat metal strap piece on the fuel tank with the hole? My CA had one, but I never knew what it was for. My 1942 B doesn't have one.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 15 Nov 2016 at 5:47pm
Imagine how much ground you could turn in a day if you had all yours working at it!
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 15 Nov 2016 at 5:51pm
The later model Bs and all of the CAs have that strap to hold the back of the gas tank. The early Bs have a bracket attached to the bottom of the tank, which then attaches to the rear hole at the top of the tool box.
Auntwayne View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Auntwayne Quote  Post ReplyReply Direct Link To This Post Posted: 15 Nov 2016 at 8:08pm
      That was the first time that I ever saw a "B" plow. Thanks for posting.
Dad always said," If you have one boy, you have a man. If you have two boys, you have two boys". "ALLIS EXPRESS"
Chalmersbob View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chalmersbob Quote  Post ReplyReply Direct Link To This Post Posted: 15 Nov 2016 at 9:31pm
A 14" plow should plow at 7" deep. You were doing a great job pulling that plow.Bob
4 B's, 1 C's,3 CA's, 2 G's WD, D14, D15, B-1, B10, B12, 712S,
ac45dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac45dave Quote  Post ReplyReply Direct Link To This Post Posted: 15 Nov 2016 at 9:38pm
nice video,thanks for posting.that little b just purrs like a cat in a creamery.Thumbs Up
R.W View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote R.W Quote  Post ReplyReply Direct Link To This Post Posted: 16 Nov 2016 at 2:50pm
Like Paul said, it's a hold down for the rear of the tank. There is a tab on the top of the tool box that it bolts to.
R.W View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote R.W Quote  Post ReplyReply Direct Link To This Post Posted: 16 Nov 2016 at 2:54pm
Thanks for the kind comments fellas, the old girl is doing pretty good after going through it this past year. I'm sure I could get the plow to pull a little nicer but I don't usually pull it with something as narrow as the B. I'm getting the 3 point hitch ready to put back on and I just installed new tires prior to the video. It's been a good little tractor.
