worn front end,D-15 II
Brian S(NY) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian S(NY) Quote  Post ReplyReply Direct Link To This Post Topic: worn front end,D-15 II
    Posted: 14 Nov 2016 at 10:54am
The front end on my D-15 II is worn out from bucket use. Im thinking of changing the loader over from trip to the full hydraulic henry loader I have. I dont dare do that untill I rebush and pin the front end. Is it possible to rebush it with the casting still attached to the tractor or does the tractor have to be torn down and the casting removed? The Henry loader is very heavy.... would it be a mistake to put it on my fifteen? I thought if I do put it on the tractor Id look for a liter bucket for it...
Kenny L. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kenny L. Quote  Post ReplyReply Direct Link To This Post Posted: 14 Nov 2016 at 11:03am
Brian, in my opinion you've to remove the cast to do the job the right way. It isn't that bad of a job. I took my to a weld shop and they redone everything that need to be redone and it made one he** of a different. HTH Kenny L.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian S(NY) Quote  Post ReplyReply Direct Link To This Post Posted: 14 Nov 2016 at 11:10am
Well if that true then I mite better look for another loader tractor, I cant see myself going without it while im waiting for the fifteen to be fixed. What other tractor would this henrey loader fit on? a 160?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 14 Nov 2016 at 11:20am
The D15 front pivot is too light for heavy loader us. The pivot pin itself is too short, could be about one inch longer IIRR. The bearing surface from factory is about an inch at best. It can be repaired to be stronger and last longer. I have done several. HTH Tracy
Dan73 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dan73 Quote  Post ReplyReply Direct Link To This Post Posted: 14 Nov 2016 at 1:01pm
Trying to think how to describe it or what it is called but there are a set of bearing in the front end above the counter weight I think that the power steering can leak around. I would replace then as well if your front end has been used that much. My d15 has a ts500 loader i am sure it is heavier then the one you want to put on it. Or it might be the one you mentioned henry did make the ts500 for the d15 industrial. it is plenty heavy with w bucket full of manure the d15 doesn't want to turn. But if you are reasonable about loading it and don't plan on using it 8 hours a day every day it will hold up nicely.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 14 Nov 2016 at 6:09pm
Get a FE off of an I-60 or I-600, not adjustable, but heavier, and bolt right up, if you can find one...Thumbs Up
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian S(NY) Quote  Post ReplyReply Direct Link To This Post Posted: 14 Nov 2016 at 6:36pm
thanks guys, lots to think about
Post Options Post Options   Thanks (0) Thanks(0)   Quote TimNearFortWorth Quote  Post ReplyReply Direct Link To This Post Posted: 14 Nov 2016 at 7:38pm
I have one to do and will definitely follow Tracy's suggestion on beefing up the depth and likely the OD of the pin itself also. I picked up a complete 415 loader with front pump a few years back and hope to get into her at some point. Jacking the entire front end off the ground and supporting it via the engine side rails, I could tell I had some wear but thought it was marginal. Then I used that same tractor to move 75 round bails with a A-C SC/3-pt. adaptor with the farthest bales a good mile from where they were to be stored. I could feel the front end "floating" as they were nice tight bales at approximately 1000-1100# and I only had two sectional pie weights attached to the engine side rails.
What I found was shined up metal at the steering knuckle/bellhousing so the sleeve type bushing just in front of the knuckle is also worn.
I will be addressing the following when we get into mine.
- Re-bush or opening up female socket with larger longer pin to match.
- R&R all gaskets/seals I find as the 15 PS is nice if it does not leak but once it starts, requires tear down as it will leak worse if not addressed.
- R&R all PS fittings as most are nearly impossible to reach once assembly is put back on the tractor.
- R&R the bushing in front of the steering knuckle (inside left side rail), to tighten everything up. Likely will tap for a zirk type fitting. Likely new knuckle as well.
- R&R top and bottom bushings in the steering "knees" as I could also see a bit of wear when moving that hay, wear that I had never noticed before.
Maybe bringing home the new to me 185 will be the driver to finally get the loader job/front end rebuild started, the old girl deserves it after all.
This page was generated in 0.149 seconds.
