raddle chain installation tips
grinder220 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote grinder220 Quote  Post ReplyReply Direct Link To This Post Topic: raddle chain installation tips
    Posted: 14 Nov 2016 at 9:28am
The ol'M2 chucked the front raddle chain on me yesterday,ended up getting its little brother the F out so I could keep going. Any tips or tricks on getting the new one put in? It doesn't look like its that big of a job but I have heard people say it's a real pain. The old chain is out already.
zulawski87 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote zulawski87 Quote  Post ReplyReply Direct Link To This Post Posted: 14 Nov 2016 at 10:18am
I ran rope around and pulled it up and back down. Easier with two ppl to keep things straight and not catching on something
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 14 Nov 2016 at 10:48am
Be sure to replace to idlers up at the top.
mruhlig77 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mruhlig77 Quote  Post ReplyReply Direct Link To This Post Posted: 14 Nov 2016 at 11:24am
You will need the rope or ropes and a long stick to guide it..good luck..a bucket full of cuss words might also help...Make sure not to put it in backwards..Mark
CrestonM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 14 Nov 2016 at 1:34pm
Well...if the old one was still in, I'd connect the new one to the old one, then pull the old one out. That way it will then pull the new one in! Then just disconnect the 2, and hook the ends of the new one together. Bingo! Done.
Post Options Post Options   Thanks (0) Thanks(0)   Quote grinder220 Quote  Post ReplyReply Direct Link To This Post Posted: 14 Nov 2016 at 3:17pm
thats what I would have done but it wouldn't work in this situation, the chain broke in 2 different spots not directly across from each other.
Post Options Post Options   Thanks (0) Thanks(0)   Quote grinder220 Quote  Post ReplyReply Direct Link To This Post Posted: 14 Nov 2016 at 8:43pm
I picked up a pair of idlers this evening but they are different from what I have on the machine. The ones on it are only about an inch wide with no shoulder,did they have 2 different types? My parts book only shows the one and thats the only kind I've seen
GM Guy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GM Guy Quote  Post ReplyReply Direct Link To This Post Posted: 24 Nov 2016 at 1:29am
the grain machines have a flat idler with a guide lip that goes to the outside.
The corn soybean machines have a sprocket idler.
Either will work, just make sure to use a matched pair.
It sounds like they might have tried giving you a plain chain idler with no shoulder?
Do you take the cover off in the off season? IMO leaving the cover on is the leading cause of raddle chain failure. leaving it on causes rusty links, which cause future failure IMO.
Gleaner: the properly engineered and built combine.
If you need parts for your Gleaner, we are parting out A's through L2's, so we may be able to help.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 24 Nov 2016 at 9:43am
I remove the cover at front of raddle on my F2 and blow it out while running. Lots of trash to collect moisture in there.
tbran View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 24 Nov 2016 at 5:41pm
I never saw the sprocket idlers for the short raddle... 71160426 is the #, anyway loosen the bottom and pullit all the way back, the chains used to come with S pins for the master, for a very good reason .  Check the front drive sprockets as well.  After installation tighten the chain so as to have to push hard to move the chain on the sprockets.  After 8 hours of operation it will have to be tightened again ,  It is imperative to keep this chain tight, other wise backfeeding will bend and break the chain, .   Make sure the anti backfeed fingers are in place and just miss the back raddle.
