D12 engine Sleeves
CTALLIS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTALLIS Quote  Post ReplyReply Direct Link To This Post Topic: D12 engine Sleeves
    Posted: 11 Nov 2016 at 3:56pm
Are the sleeves in a d12 the same as a model B or C?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 11 Nov 2016 at 10:30pm
NO.
GregLawlerMinn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GregLawlerMinn Quote  Post ReplyReply Direct Link To This Post Posted: 12 Nov 2016 at 8:38am
The D12 has the same engine as the D14 (149CI); except the earlier D12's had a smaller bore (138CI). The 149 CI piston/sleeve will drop right in the 138CI block.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTALLIS Quote  Post ReplyReply Direct Link To This Post Posted: 12 Nov 2016 at 2:54pm
thanks,
next question
anybody got a good used sleeve.
wbecker View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wbecker Quote  Post ReplyReply Direct Link To This Post Posted: 12 Nov 2016 at 5:37pm
Also the same as later D10 149 engine.
What are you intending to use the tractor for?
I do have a sleeve you could have, it's not perfect, but not too bad.
It would be easily good enough for a show/parade tractor. Maybe other occasional work.
What is the condition of the one your replacing?
You can have it for the shipping if you want it.
Bill B
Edited by wbecker - 12 Nov 2016 at 6:20pm
This page was generated in 0.170 seconds.
