Will it work
Orange4ever View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orange4ever Quote  Post ReplyReply Direct Link To This Post Topic: Will it work
    Posted: 11 Nov 2016 at 1:15pm
We ordered a new carb for our b-110 and plan on putting it on this week but we need to know if this elbow from the carb to the engine will work. It's not the original and was on it when we got it. thanks, tom
If you want a man to be a successful farmer, give him a Allis Chalmers tractor. If you want him to be a successful mechanic, give him a John Deere
shameless (ne) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless (ne) Quote  Post ReplyReply Direct Link To This Post Posted: 11 Nov 2016 at 2:09pm
as long as it fits and seals, should work. appears it was modified a bit already!
ACmowerguy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACmowerguy Quote  Post ReplyReply Direct Link To This Post Posted: 11 Nov 2016 at 10:56pm
I don't believe the 10hp carb will bolt onto that elbow. If its the Chinese aftermarket carb, the air cleaner probably won't fit correctly either.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orange4ever Quote  Post ReplyReply Direct Link To This Post Posted: 12 Nov 2016 at 6:51am
We purchase the correct Briggs & Stratton carburetor and the Nelson muffler for the tractor and after some more information we found the Pic elbow will not work the original elbow there's two styles a short and long and they're both offset a little bit so the air cleaners can work we should have one coming in this week.   Was armrest on the seat standard or was that an option
macvette View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote macvette Quote  Post ReplyReply Direct Link To This Post Posted: 12 Nov 2016 at 11:30am
I believe standard. All the B-207 and up seem to have them.  Possibly someone more knowledgeable than me knows for sure.  If you have holes in the chrome bars reaching from the seat back, there were armrests on it originally.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACmowerguy Quote  Post ReplyReply Direct Link To This Post Posted: 12 Nov 2016 at 2:47pm
Yes it should have had armrests.
talntedmrgreen View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote talntedmrgreen Quote  Post ReplyReply Direct Link To This Post Posted: 15 Nov 2016 at 9:51am
The carburetor pictured is from a smaller hp machine, and will yield less fuel mixture flow, i would think.  The intake appears smaller than what was intended for that carb, so that would further limit your feed to the engine.  Carbs and intakes are common for these...I bet you could get the correct setup cheap.
Patterson B1*B1/B1Forklift*B10*BigTen/B1Loader*B110*B208*B206*616*Homelite T16H/T8/T7/RM7E*Landlord/Loader/Trencher*Broadmoor717*Serf525*2110*7790*Legacy XL*Twin 20*Squire9*Squire6*JCPenny 494
