Removing B Thermometer Probe
1939Dodge View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 1939Dodge Quote  Post ReplyReply Direct Link To This Post Topic: Removing B Thermometer Probe
    Posted: 11 Nov 2016 at 11:13am
The probe end of the thermometer is stuck in the housing. I assume it's just inserted,not a press fit or thread, and that its just corroded in. But I don't want to bust the housing.
Suggestions on how to remove? Heat it and drive it through the housing?
Alberta Phil View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alberta Phil Quote  Post ReplyReply Direct Link To This Post Posted: 11 Nov 2016 at 5:45pm
If the gauge part is twisted off and it's just the tube stuck in there, I've drilled them out.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 1939Dodge Quote  Post ReplyReply Direct Link To This Post Posted: 11 Nov 2016 at 6:31pm
Luckily I had the housing on the bench. Clamped the tube in needle nosed vise grips and tapped it out.
