Allis 185 Priming and Starting
McGatha185 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote McGatha185 Quote  Post ReplyReply Direct Link To This Post Topic: Allis 185 Priming and Starting
    Posted: 10 Nov 2016 at 4:47pm
Hey guys, thanks for helping. So here's the problem. I have a 1970 Allis 185 Crop Hustler. I've been beating my way through college and finally graduated this last spring, so now I'm finally starting to come back to life, and do some work around the farm, but it's been awhile since I started this tractor. I had 20 gallons of fuel in it with conditioner so it wouldn't go bad. It didn't go bad, it just isn't there anymore. It all leaked out. I didn't have the valve turned off at the sediment bowl and the priming pump was worn out, so it leaked around the priming pump and drained the entire system.
So trying to get it started, I have cleaned the sediment bowl, put on a new fuel filter filled with new fuel, I put new fuel in the tank and made sure the lines were clear. I then bought a new priming pump since mine would squirt back at me every time I pumped it... it works good now. I pumped the living crap out of it, making sure nothing but fuel is coming out of the petcock on the fuel filter, and only fuel is coming out of the feed line to the fuel pump. I pumped some more, making sure my throttle was set all the way open, and I pulled the timing plate from the fuel injector pump to make sure fuel was dripping good. All is well so far. I've never needed more than this for it to start, but it just won't. So I tried to loosen the feed line nuts on the injectors. Problem with this is that this dog has an old type of coupling system (??Ernesto...Ermesto...something like this??) that sticks hard. You need to pull them loose. I could only get two to pull loose while the rest wouldn't budge, and I was starting to bend the fuel lines trying! I even shot it down with blaster to try and loosen them up.
I pumped a ton more on it. Over a 1000 times and it still won't even try to hit. I never seen a drip come from the injector lines. I even had a friend hold an air nozzle in the fuel tank with a rag around it to artificially pressurize the system, and hopefully push some fuel through it. Didn't work. This was running just fine when I shut it down last. It should start! The engine turns free and nice. What else can I do? I've read several threads talking about this same subject but they're always for 160's or 175's and never quite relate to my fuel injection system. At least they don't seem to relate when I try to find what's being talked about. My dad used to own a 180 and the only time it didn't start the local mechanic used a shringe of diesel fuel and manually shot fuel into the injectors. Is that a way? How about taking loose the fuel return line so the air can pump out? I don't know. Maybe my throttle is stuck shut. I just don't know. Please help!!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote McGatha185 Quote  Post ReplyReply Direct Link To This Post Posted: 10 Nov 2016 at 4:54pm
Reading back through this, I want to point out for those who might misunderstand that I loosened the retaining nuts holding the fuel lines into the injectors, but the lines themselves will not pull out of the injector bodies. I could feel a slight pop when I pulled on two of these lines and they moved a tiny bit, indicating they came loose. The other four are stuck fast in the injectors, and I'm afraid of the damage I'll do trying to force them out. I'd hate to make a big problem out of a little one.
Thanks for helping!
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 10 Nov 2016 at 5:32pm
most likely the pumping plungers in the pump are gummed up and stuck. If this is the case, the pump will need to be serviced, and for best results, the injectors also. I've seen this over and over. Today's fuel does not do well when left to sit.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 10 Nov 2016 at 6:50pm
Are you sure you have the fuel shut off out?
Post Options Post Options   Thanks (0) Thanks(0)   Quote McGatha185 Quote  Post ReplyReply Direct Link To This Post Posted: 10 Nov 2016 at 7:06pm
Yeah, I've opened it up. Every time I use the priming pump I can see the sediment in the bottom of the bowl stir up.
critter View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote critter Quote  Post ReplyReply Direct Link To This Post Posted: 10 Nov 2016 at 7:54pm
I think he meant the pull knob on the dash
Post Options Post Options   Thanks (0) Thanks(0)   Quote McGatha185 Quote  Post ReplyReply Direct Link To This Post Posted: 10 Nov 2016 at 8:03pm
There is no pull knob on the dash. My dad's old 180 had one, I know, and there's a spot on this dash for one, but when I got it, there was no pull knob. I'm sure some farmer reworked it a long time ago. Mine is set up to flip a toggle and push the button. It's always worked fine, so I've never felt to need to change it. I'm just starting to fix this old guy up, so I'll probably put it back to factory stock.
Lynn Marshall View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lynn Marshall Quote  Post ReplyReply Direct Link To This Post Posted: 10 Nov 2016 at 8:25pm
If it doesn't have a manual shut off cable, it may have an electric one like a lot of the combines. Is there a wire on the top of the pump? If so, do you have power there when the toggle switch is turned on?
Post Options Post Options   Thanks (0) Thanks(0)   Quote McGatha185 Quote  Post ReplyReply Direct Link To This Post Posted: 10 Nov 2016 at 8:27pm
It does have a wire on top of the pump. I never thought of checking it. I'll go see right now what my meter says.
Post Options Post Options   Thanks (0) Thanks(0)   Quote McGatha185 Quote  Post ReplyReply Direct Link To This Post Posted: 10 Nov 2016 at 8:36pm
Ok, I checked the battery and it was showing almost 15 volts. I flipped the toggle and checked the little wire coming into the top of the pump and it says 0 volts. But when I tried to turn the engine over with the toggle off it won't do it but it will spin free with it on. Is the little wire a ground maybe? It goes up to the hood and then snakes its way under the hood by the fuel tank before I lose it. I'd have to pull the hood. Isn't there some sort of switch on the clutch to stop it from starting in gear?
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 10 Nov 2016 at 8:58pm
Unhook the wire at pump, then run a jumper wire from battery or starter to that post. Be sure to unhook it when you are done. When you hook and unhook wire to terminal, you should hear  a click in pump if it is working.   MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote McGatha185 Quote  Post ReplyReply Direct Link To This Post Posted: 10 Nov 2016 at 9:04pm
Ok, I'll do this but it'll have to be tomorrow. I'm going to work now.
Thanks a ton!!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote McGatha185 Quote  Post ReplyReply Direct Link To This Post Posted: 11 Nov 2016 at 12:25pm
This is the wire I'm talking about. I don't see any solenoid that it'd be kicking in. Is this right? The moisture is from degreaser I just sprayed on it.
Leon B MO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Leon B MO Quote  Post ReplyReply Direct Link To This Post Posted: 11 Nov 2016 at 1:11pm
Do as Mack said above. Take that wire off, and run a temporary hot wire to that post. You'll here a click inside the pump, if so try to start the motor. You will have to disconnect the wire to kill it, might use an alligator clip on the battery end of the temporary wire. Could be mice got to some wiring behind the dash, might check that too.
Leon B
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lynn Marshall Quote  Post ReplyReply Direct Link To This Post Posted: 11 Nov 2016 at 1:12pm
You need 12 volt power to that wire to make it start. There's a small solenoid under the pump cover to make it work.
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 11 Nov 2016 at 1:44pm
Those two nuts sticking out the top of pump are the solenoid terminals. One side is the switched 12v, the other should be ground, most just have a small strap that goes right to the front cover attaching screw. Some safety switches use the ground side to kill the engine, so check the ground and hot sides of the solenoid terminals. Like said above, you should hear it "click" inside the top cover of the pump.
Post Options Post Options   Thanks (0) Thanks(0)   Quote McGatha185 Quote  Post ReplyReply Direct Link To This Post Posted: 11 Nov 2016 at 4:10pm
Sorry, that wasn't it. When I checked it last night, I grounded my meter on the painted loader. My meter didn't like the paint. I took the wire loose and set up wire with alligator clips from the battery to the post. It clicked, but when I tried to check the voltage, I got zero again. I grounded on the bare hydraulic cylinder and it showed the volts. I rechecked my wire and it showed me volts now too. So the wire is good. Sorry about that. I did hear the solenoid click too with the tractor's wire. Should I have a ground wire off this pump?
Post Options Post Options   Thanks (0) Thanks(0)   Quote McGatha185 Quote  Post ReplyReply Direct Link To This Post Posted: 11 Nov 2016 at 4:24pm
I just checked on the ground strap Ed mentioned and it's still there. It looked like it was broken at first but it just has a 90 degree bend in it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 11 Nov 2016 at 5:03pm
If you hear it click, then it's working. Like I stated in my earlier post, the pump internals are very likely gummed up from sitting in the old fuel, and the plungers are stuck.
Post Options Post Options   Thanks (0) Thanks(0)   Quote McGatha185 Quote  Post ReplyReply Direct Link To This Post Posted: 14 Nov 2016 at 3:53pm
Ok, I'm going to try and clean this up a bit. I'm going to take the fuel lines loose, and open the two screws on the timing tab to drain out the diesel. Then I'm going to pour in some Diesel Kleen and let it sit for awhile. Then I'll open it up again and drain it out. Maybe that'll un-gum it.
If this is good or bad or you have a better way, please let me know.
Thanks!
Post Options Post Options   Thanks (0) Thanks(0)   Quote McGatha185 Quote  Post ReplyReply Direct Link To This Post Posted: 14 Nov 2016 at 3:56pm
Ah, another thought. There's a little screen just inside where the fuel enters the injector pump, right? Could that be blocked or gummed up? Can I easily disassemble this part and clean it up?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 14 Nov 2016 at 4:47pm
Tractor must have had a combine engine grafted into it. Tractors never had electric shut-off except the D-21.
Post Options Post Options   Thanks (0) Thanks(0)   Quote McGatha185 Quote  Post ReplyReply Direct Link To This Post Posted: 14 Nov 2016 at 4:51pm
You know, there is something odd about this tractor. The paint on the engine is flaked off here and there, and it's yellow underneath. I assumed that either 1) it may be really faded Allis orange that they painted over or 2) the tractor may have been a road department yellow tractor back in the day. Maybe it does have a different engine. I don't know. How would I find out for certain?
