I'm Stumped...
Slim View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Slim Quote  Post ReplyReply Direct Link To This Post Topic: I'm Stumped...
    Posted: 10 Nov 2016 at 11:09am
So I've been working on a Kubota B7100 tractor trying to get it running. Glow plugs are good, injectors tested good, pump is pumping fuel as it should, compression is good...but it simply will not start. What am I missing here?
-Slim
AC 1971 170 WF Gas, AC 185 Diesel WF, AC WD NF, AC '54 WD45 NF, AC 7080, AC 7030, Wheel Horse D-180 Automatic
Dmpaul89 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dmpaul89 Quote  Post ReplyReply Direct Link To This Post Posted: 10 Nov 2016 at 11:13am
is it making any smoke out the muffler? if it is you may need to spin it faster or warm the block if its cold
Slim View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Slim Quote  Post ReplyReply Direct Link To This Post Posted: 10 Nov 2016 at 11:16am
Yes, when cranking it smokes out the exhaust.
-Slim
Gary Burnett View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 10 Nov 2016 at 11:26am
Hook another tractor to it and pull it that'll start a hard starter lots of times.You just might not be spinning it fast enough or not building compression pulling it will help over come both plus you won't be burning up your starter.
WD45Diesel57 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WD45Diesel57 Quote  Post ReplyReply Direct Link To This Post Posted: 10 Nov 2016 at 11:32am
check the timing, if its a wee bit off will make them hard to start
1-B's, 2-C, 2-CA's,2-WF, 1-WC,1-G, 3-WD's, 2-WD45, 1-RC, 1-D17 Diesel, 1-D14, 2-D15,1-D17 row crop,1-D19 gas and All Crop 40,60,66,72,90 and 100
kev/ont View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote kev/ont Quote  Post ReplyReply Direct Link To This Post Posted: 10 Nov 2016 at 11:59am
Did u test each glow plug seperately with the common exciter strip removed? If even one plug isnt working they will be a bear to start.
LB0442 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LB0442 Quote  Post ReplyReply Direct Link To This Post Posted: 10 Nov 2016 at 1:52pm
I used to have one of those.  I lent it to my dinkus neighbor and he ran it out of fuel.  I went up with fuel, cracked injector lines, had all kinds of fuel out them, still wouldn't run.  Ran the battery down couple of times trying.  Well looked it over and there is a plug on the top of the injection pump (could be on the side near the top).  It was a 3cyl diesel.  Cracked that while cranking, fired right up??  I guess that is how they bleed out air.  Just something I ran into.
BrianC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BrianC Quote  Post ReplyReply Direct Link To This Post Posted: 10 Nov 2016 at 6:08pm
Why do we keep loaning tractors and tools to neighbors? Will we never learn?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 10 Nov 2016 at 6:12pm
pull the glow plugs, and test compression, most don't start well if its under 250-300 PSI.
Timing not much of an issue, on Kubotas, cartridge style injector pump, gasket thickness is the way you time 'em...
