Fixing an All-Crop Cylinder Tach
CrestonM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Topic: Fixing an All-Crop Cylinder Tach
    Posted: 08 Nov 2016 at 7:32pm
Seeing Dennis' post about the All-Crop with the corn head got me wondering...If I got a cylinder tach for one of my combines, but it didn't work, is there any way to fix them/have them fixed? I've had people tell me it's impossible and once it's broke, it's broke. Is this true?
Thanks
Ryan Renko View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ryan Renko Quote  Post ReplyReply Direct Link To This Post Posted: 08 Nov 2016 at 7:42pm
I believe the SPs used a different tach then the one you saw in the video. If you sweet talk my brother he just might let go of the one he has hanging in our shed complete with cable and nut attachment that will fit your SP. I have several  tachs for the pull types. Ryan
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 08 Nov 2016 at 8:05pm
Thanks Ryan! That's music to my ears. Wasn't expecting to hear something like that.
While a cylinder tach on my Super 100 isn't "100"% necessary (Lol), it would be convenient since the cylinder speed adjust crank is near the operator's station. Without the tach mounted on the combine, you adjust the speed, crawl down, run to the other side of the combine with your handheld tach, get a reading from the cylinder shaft, run back, climb on the platform, adjust some more, crawl back down, run around and get another reading, etc.
As good of news as that is,  I'd still like to know if broken ones can be fixed. Seems a shame to get a working one and actually hook it up and use it if it can't be fixed if it breaks.
Edited by CrestonM - 08 Nov 2016 at 8:23pm
Chad(WI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chad(WI) Quote  Post ReplyReply Direct Link To This Post Posted: 08 Nov 2016 at 8:51pm
A tach like this?
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 08 Nov 2016 at 9:48pm
That's similar. The originals I've seen say 200,400....1600, etc. They have all the zeros on them.
I'm guessing that's a repro? If so, where did you get it?
Edited by CrestonM - 08 Nov 2016 at 9:50pm
DennisA (IL) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DennisA (IL) Quote  Post ReplyReply Direct Link To This Post Posted: 08 Nov 2016 at 10:14pm
 I checked into it about 10 years ago and could find any place that would touch it. I did call the manufacturer of the tach and they had a 100 of them on the shelf that they destroyed 6 mouths prior.  What a waste.
Thanks & God Bless
Dennis
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 08 Nov 2016 at 10:19pm
Wow...were they actual A-C combine tachs?
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 08 Nov 2016 at 10:47pm
What a waste.
WOW! Can you say "Richard Crainium"
Dmpaul89 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dmpaul89 Quote  Post ReplyReply Direct Link To This Post Posted: 08 Nov 2016 at 11:13pm
What goes wrong with them? Can't be that complex.   I fix watches for a living maybe someone wants to donate me a broken one to tinker with?
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 08 Nov 2016 at 11:33pm
If I had one, I'd send it to you!
 I know where I *may* can get a broken one (needle is stuck at 450 RPM), but it's on a combine and the guy doesn't sell ANYTHING. Usually... I don't know if he'd part with a tachometer. He's a Massey guy.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DennisA (IL) Quote  Post ReplyReply Direct Link To This Post Posted: 08 Nov 2016 at 11:59pm
 Yes they were.
Thanks & God Bless
Dennis
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 09 Nov 2016 at 12:11am
 Yes they were.
Oh no.....Now I'm feeling sick...
