180 power director valve
shackratt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote shackratt Quote  Post ReplyReply Direct Link To This Post Topic: 180 power director valve
    Posted: 08 Nov 2016 at 5:22pm
I have a 180 power director valve that I cannot seem to get the spool to come out. It is stuck pretty good. Anyone have any ideas on how to get the inner spool out?
Thanks in advance
Sam
AC 180, TO-20, Case 580B Case 450 dozer
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 08 Nov 2016 at 10:07pm
Do you mean the one the shifter is hooked to or the pressure regulator?    MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote shackratt Quote  Post ReplyReply Direct Link To This Post Posted: 09 Nov 2016 at 4:28am
Mack,  The valve that is connected to the handle to switch from High to Low. I have removed the valve and tried to remove the inner spool. The little plunger with the spring comes out but the upper most portion (cup) will not come out. I have tried soaking it for days. I was thinking of drilling a small hole inline with it and pushing it out that way then tapping and plugging the hole. The tractor stays in High even if you shift to low.
thanks for the reply
sam
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 09 Nov 2016 at 7:10am
Just find yourself a used valve from a 180 or 185.
WD45Diesel57 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WD45Diesel57 Quote  Post ReplyReply Direct Link To This Post Posted: 09 Nov 2016 at 10:38am
i have a good one here on a parts machine if needed, the lever clicks through smoothly but sharply
1-B's, 2-C, 2-CA's,2-WF, 1-WC,1-G, 3-WD's, 2-WD45, 1-RC, 1-D17 Diesel, 1-D14, 2-D15,1-D17 row crop,1-D19 gas and All Crop 40,60,66,72,90 and 100
This page was generated in 2.922 seconds.
