Hydraulic Problem 190XT
grkin57 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote grkin57 Quote  Post ReplyReply Direct Link To This Post Topic: Hydraulic Problem 190XT
    Posted: 08 Nov 2016 at 2:26pm
When lifting bucket, it jumps or hops continuously while lifting, even when bucket is empty.  Entire tractor hops when bucket hops.  Steering also has a  jerk - especially when turned all the way to left or right.  Changed hydraulic filter, but it did not make a difference.
Charlie175 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 08 Nov 2016 at 2:36pm
Air infiltration issue
Either the suction tube or elsewhere.
Also on the front of the pump is a seal that goes back allowing air to suck in from engine.
Else your pump is going out.
Charlie
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 08 Nov 2016 at 3:53pm
Check the hydraulic oil before you do anything else. Now, where do you check it??
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 08 Nov 2016 at 5:18pm
Ah yes, do the obvious first!
Charlie
tbran View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 09 Nov 2016 at 9:46pm
does the unit have low profile tires, you didn't pick the unit up from a street salesman in LA did you?    :-)    As stated you have a low oil issue or a bad front pump seal. You are "sucking air"  intermittently
