F3 adjustment
Shawn PA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Shawn PA Quote  Post ReplyReply Direct Link To This Post Topic: F3 adjustment
    Posted: 08 Nov 2016 at 11:18am
I can't figure out how to get my new to me F3 adjusted right. First it was throwing corn into the walkers and they was throwing it out the back. And it also going over the cives right out the back. It's 150 bps corn and I'm down to 1.7 mph. And the bin is very dirty with stalks and cob pieces. I moved the walkers all the way back and tried air settings but I can't get it. Thanks Shawn
Post Options Post Options   Thanks (0) Thanks(0)   Quote Skyhighballoon(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 08 Nov 2016 at 11:31am
I know one of the questions is going to be long or short finger chaffer?  Mike
1968 Gleaner EIII w 10' & 330
1969 180 gas
1965 D17 S-IV gas
1963 D17 S-III gas
1956 WD45 gas NF PS
1956 All-Crop 66 Big Bin
Post Options Post Options   Thanks (0) Thanks(0)   Quote Shawn PA Quote  Post ReplyReply Direct Link To This Post Posted: 08 Nov 2016 at 11:51am
That I don't know. I think long round end maybe ?
CrestonM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 08 Nov 2016 at 12:00pm
Pics would help a lot.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 08 Nov 2016 at 12:09pm
To start: 5/8" on the cylinder......500 RPM........fan at 6......long finger chaffer (top)at 3/8" open (use a 3/8" bolt for your gauge), lower sieve wide open......walkers 2 inches back from being clear forward in the slots. There are probably better settings than these, but this should work. You don't mention moisture levels, and that is important. There is a tremendous diff between 25% and 18% corn when it comes to combine performance. Your capacity is the greatest on LEVEL LAND. Any side lean can cut your capacity in half or more, depending on the slope percentage. So, if you can run 2 MPH on the flat, you might be down to 1 MPH on a side slope. I hope you have a 3 or 4 row corn head, and not a 6 row. ENGINE RPMS MUST BE FULL SPEED AND AT THE TOP OF THE RPM RANGE---GAS IS DIFFERENT (2900) THAN DIESEL (2400-2450). YOUR COMBINE IS ONLY A 500 BPH MACHINE !! SO DON'T THINK YOU CAN RUN 4 MPH IN CORN. FOUR HOPPERS AND HR IS ABOUT IT.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Shawn PA Quote  Post ReplyReply Direct Link To This Post Posted: 08 Nov 2016 at 1:18pm
My corn is 17% I have a 4 /30 head. It is a slope but not much at all. I mean the bin will fill level on this slope. Why am I getting corn in the straw walkers ?    I do kno my rpms is 2350 I do remember that.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Shawn PA Quote  Post ReplyReply Direct Link To This Post Posted: 08 Nov 2016 at 1:19pm
I kno that but I'm at work.
Dmpaul89 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dmpaul89 Quote  Post ReplyReply Direct Link To This Post Posted: 08 Nov 2016 at 2:22pm
i had to run my f as slow as it would go in 1st. i was only getting two hopper fulls in an hour or about 200 bushel.   i had my cylinder at slightly more that 5/8ths. and 500 rpm. chaffer 3/8ths fan full blast.     also i am running 3 concaves (channel) and the agressive cylinder bars.           i suspect your chaffer is closed too much not letting corn fall past it. not sure on why you have corn going out the walkers are you saying you have cobs with kernals still on them walking out the back? if so cylinder adjustments needed
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 08 Nov 2016 at 2:23pm
2350 RPM is too slow. I can tell lots of stories about inaccurate tachometers. Make absolutely sure the throttle lever on the injection pump hits the wide-open stop screw. A diesel is probably close to correct speed as long as it hits the stop....an extra 100 RPM helps.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 08 Nov 2016 at 2:24pm
Your pulley on the cylinder has to be 16.5 inch or 20 inch diameter....WHAT IS IT??
Jordan(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jordan(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 08 Nov 2016 at 2:29pm
Half round concave at 2-4-6, good wide spaced bars, chaffer mod on long tooth chaffer and you can run as fast as it will go in 3rd gear.
Edited by Jordan(OH) - 08 Nov 2016 at 2:30pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 08 Nov 2016 at 2:34pm
crank it to 2450!! high idle.Your raddle should b throwing some corn on the front of walkers.Do you have the rizers on walkers?
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 08 Nov 2016 at 2:38pm
a hand held tach on end of shaft is most accurate.The one in cab is adjustable so could be off.Can set cab one to real known number
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 08 Nov 2016 at 2:42pm
Shawns at work...all this info is probalby killing him....
wekracer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wekracer Quote  Post ReplyReply Direct Link To This Post Posted: 08 Nov 2016 at 3:29pm
Something doesn't sound right. I could get a full hopper every 15 minutes in 180 bushel corn with my F2 with 4-30 orange head. That's probably 2.5-3 mph. What is your cylinder speed.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Shawn PA Quote  Post ReplyReply Direct Link To This Post Posted: 08 Nov 2016 at 4:24pm
It is a 20 inch pulley. I do have risers on the walkers. Mine is a hydro so I don't think I could stay in the seat in 3rd gear. Lol. I don't kno what the cylinder speed is. It stopped working the other night. I have cylinder set at 1/2 and lowered speed till I seen corn left on the cob and went up till it was off.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 08 Nov 2016 at 6:09pm
The 1 5/8" long tooth corn chaffer is a MUST for capacity and good cleaning. Look in your Operators manual for a picture of the 1 5/8" chaffer versus the 1 1/8" standard chaffer.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jordan(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 08 Nov 2016 at 7:13pm
3rd on a variable speed is 4-4.5
Post Options Post Options   Thanks (0) Thanks(0)   Quote Shawn PA Quote  Post ReplyReply Direct Link To This Post Posted: 08 Nov 2016 at 7:51pm
Wow. I couldn't even begin to think of going that fast. We are getting rain so I'll reset the machine and see what happens. Thank you
AC7060IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC7060IL Quote  Post ReplyReply Direct Link To This Post Posted: 08 Nov 2016 at 9:52pm
Cob pieces & stalks in grain tank, plus it's spitting corn out back, means the Chaffer is clogged with cob pieces. Clean your Chaffer/sieve. Your Hybrid might be soft cob or disease, so cylinder filler bars may help? Anyway, try opening cylinder to minimize cob breakage while also speeding up forward travel to crowd capacity on incoming ears to cylinder so more ears are threshing grain before cylinder. Opening cylinder (5/8-3/4") gives cobs room to stay whole.   Slower travel speed puts fewer ears into already tight (1/2") cylinder which tends to breaks cobs.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 08 Nov 2016 at 10:04pm
There is always corn on walkers, but it should fall through and slide forward and fall on front of shoe. If walkers are plugged with cobs, the corn will go out the back. MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 08 Nov 2016 at 10:33pm
The return elevator is your speed monitor.Pick up ground speed til you start washing corn over in the return,then back off enough get it down to just a few kernals per paddle(10 or less?).I run a needle width under 4mph in 18% 200bu corn and don't fill the return with corn or throw it out the back.The walkers carry a bit to the chopper cause there's random kernals in adjacent rows....it still does it at 3mph so forget it.Had a 19.5 A field @17% which averaged 201bu #2 yellow corn.That's how it got picked. 4-30 black head,wide space bars,2 rasp concaves,speed up kit clean grain,modified long round tooth chaffer,3/4 clearance,550rpm,air wide open.I don't measure screens,just eyeball em.Front section chaffer 3/4,middle 1/2 +,back...a little more.Sieve 1/2?. It works for me!!!
YOU DO HAVE THE SCREENS IN THE WALKERS DON'T YOU?
Edited by SteveM C/IL - 08 Nov 2016 at 10:35pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Shawn PA Quote  Post ReplyReply Direct Link To This Post Posted: 09 Nov 2016 at 5:22am
Yes screens are in place. I'm going to try to open it up some and go a little faster. I'd be happy with 2.5   I kno I had some cob rot this year but not as much as I thought. I'll clean every thing up and start fresh.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 09 Nov 2016 at 9:20pm
Try 3mph,then stop and check the ground....the width of all 4 rows.I don't know how fast you can go in good corn with std clean grain sprocket before you slug the elevator.Years ago my cousin was picking dad's corn with an F and would plug the elevator if pushing too hard.My guess is that it didn't have speed up kit.It hasn't been said in this thred yet but the curtain above the raddle needs tied up or removed for corn.I took mine out as I only do corn and soys.Needed in wheat.
tbran View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 09 Nov 2016 at 9:40pm
check your fan blades and choke. IF the fan blades have a build up from corn sap they will coat over and reduce air flow by as much as 50%  - make sure the air choke is wide open - up away from the fan. Check to see if you ever see shucks on the sieve - if so you have an rpm or fan volume issue.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 10 Nov 2016 at 9:45pm
details on fan choke adj are well stated in book
