Oxnard SC Spring Tooth Question
Armand(AZ) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Armand(AZ) Quote  Post ReplyReply Direct Link To This Post Topic: Oxnard SC Spring Tooth Question
    Posted: 07 Nov 2016 at 4:48pm
Did AC or Oxnard make a snap coupler spring tooth harrow??? I see pull type and three point but no SC. Bought a precision Oliver STH model last week at the toy show. Appears to scale about 8FT so thought I would convert it to SC and display it with a WD. If you have a photo or a link to a photo let me know. Tks,   Armand
Bruce(IA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bruce(IA) Quote  Post ReplyReply Direct Link To This Post Posted: 07 Nov 2016 at 5:53pm
Is this what your looking for? I think it's Oxnard
I sold it to somebody, can't remember who
Post Options Post Options   Thanks (0) Thanks(0)   Quote Armand(AZ) Quote  Post ReplyReply Direct Link To This Post Posted: 07 Nov 2016 at 7:01pm
Thanks Bruce, but that's not it. Here's a link to the pull type spring tooth harrow.
http://picclick.ca/Allis-Chalmers-Spring-Tooth-Harrow-Operators-Manual-DCPA6-152229874285.html
Allis dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis dave Quote  Post ReplyReply Direct Link To This Post Posted: 08 Nov 2016 at 7:05am
I don't remember seeing a snap coupler spring tooth harrow in Norm's book. Doesn't mean it's not there though. I tend to ignore things I'm not looking for.
Gary Burnett View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 08 Nov 2016 at 8:00am
Are you talking about the type harrow that has the curled in a circle shanks and about
1 inch square?If so yes they built that in snap coupler.
Alberta Phil View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alberta Phil Quote  Post ReplyReply Direct Link To This Post Posted: 08 Nov 2016 at 10:17am
Oxnard made Snap-Coupler tool bars to fit CA, WD, WD45, D14 and D17. There is a picture of a WD45 with the spring tooth harrows on the bottom of page 237 in Norm's book.  Might give you an idea of design.
Dave (Mid-MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave (Mid-MI) Quote  Post ReplyReply Direct Link To This Post Posted: 08 Nov 2016 at 12:25pm
I have a 1964 brochure for rotary hoes, spike tooth, spring tooth, and coil tine harrows. Snap Coupler spring tooth harrows were made in 8, 10, 12, and 16 foot sizes. I believe that I also have a parts manual that shows snap coupler spring tooth harrows. The parts manual has better photos. I can copy pages and send them if needed.
JimIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JimIA Quote  Post ReplyReply Direct Link To This Post Posted: 08 Nov 2016 at 4:53pm
This one was built in Lacrosse. Armand, the one you pictured was also built in Lacrosse.
Jim
Dave (NE) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave (NE) Quote  Post ReplyReply Direct Link To This Post Posted: 09 Nov 2016 at 10:05am
They made them. I have two. One is 12' and the other 16'. I'll see if I can find a picture of them. Dave
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave (NE) Quote  Post ReplyReply Direct Link To This Post Posted: 09 Nov 2016 at 10:10am
Here we go with a pix of the 12' one. I also have a manual for it and have seen pictures in C.H. Wendel Allis Chalmers story book.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave (NE) Quote  Post ReplyReply Direct Link To This Post Posted: 09 Nov 2016 at 10:21am
Found a few more pictures.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave (NE) Quote  Post ReplyReply Direct Link To This Post Posted: 09 Nov 2016 at 11:26am
I have one of what Bruce pictured, which I refer to as a field cultivator. Here is a pix.
Had some more pix I was going to put on, but photobucket is not cooperating.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave (NE) Quote  Post ReplyReply Direct Link To This Post Posted: 09 Nov 2016 at 11:32am
Try again.
Post Options Post Options   Thanks (0) Thanks(0)   Quote JimIA Quote  Post ReplyReply Direct Link To This Post Posted: 09 Nov 2016 at 12:01pm
Great pictures Dave. The first one you pictured looks like an Oxnard built machine, the later is definitely a Lacrosse built too.
Jim
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 09 Nov 2016 at 10:49pm
Good pictures. I like the field cultivator
Post Options Post Options   Thanks (0) Thanks(0)   Quote Armand(AZ) Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jan 2017 at 5:35pm
Thanks Dave and Bruce for taking the time to post the pictures. The next model project is the spring tooth like Dave posted. Pictures of the hitch will be a great help. I have already built a similar model of the field cultivator.
Armand
shameless (ne) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless (ne) Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jan 2017 at 9:54pm
I saw one on an auction a few weeks ago, looked kinda like the last pic above.
truckerfarmer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote truckerfarmer Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jan 2017 at 8:02am
I have one like the one in the last set of pics. I made hiller discs to fit it and use it to cultivate taters.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Armand(AZ) Quote  Post ReplyReply Direct Link To This Post Posted: 12 Feb 2017 at 2:47pm
Well, I finally got the spring tooth harrow finished. I ran across a harrow at the NATS in IA last fall and decided to buy and use it. It was part of an Oliver precision set. I built the framework from the pictures provided here and some slight modification to the harrow levers to make it more AC. Thanks for the photos and info for this project. Here are a couple pictures and there are more on my website.
Armand
old farmer View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote old farmer Quote  Post ReplyReply Direct Link To This Post Posted: 12 Feb 2017 at 3:14pm
The spring tooth harrow was made by kovar (spelling) in snap coupler, three point, and a wheel cart style. I put a lot of them together while working at the dealership. I still have a 10ft 3point one.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Armand(AZ) Quote  Post ReplyReply Direct Link To This Post Posted: 12 Feb 2017 at 3:35pm
Thanks for the info!! I had never heard of Kovar. Went and Googled it and the company was in Owatanna, MN.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 13 Feb 2017 at 9:35am
As usual Armand.............looks GREAT!!  Nice job!
Interesting history lesson too.........Kovar.
