Looking for 616 Tire chains/wheel weights
bamaboy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bamaboy Quote  Post ReplyReply Direct Link To This Post Topic: Looking for 616 Tire chains/wheel weights
    Posted: 06 Nov 2016 at 7:30pm
I have the turf tires on my 616, can anyone tell me what size chains to buy, and best place to get them? Ive looked on eBay, but many many different sizes. Or does anyone have a set they would part with? I'd also be interested in any wheel weight info or leads.
Thanks, bama
Edited by bamaboy - 06 Nov 2016 at 8:07pm
macvette View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote macvette Quote  Post ReplyReply Direct Link To This Post Posted: 07 Nov 2016 at 9:11am
As handy as you are with making implements for your 616, you could probably take off the wheels, line the inside of the rims with a sheet of plastic, put a couple of bolts thru the rims where wheel weight bolts would go, put a piece of pipe around each bolt, put washers and nuts on, and pour the "just add water" cement that comes in a bag in the rims for weights.
Jack C View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote Jack C Quote  Post ReplyReply Direct Link To This Post Posted: 08 Nov 2016 at 9:49am
I have a used set from a 720 I had with a snowblower on it. It had the Turf Tire on it. If your 616 has this tire (it should) my chains will fit.
These have been sold 12/7/16.
Lawn/turf rear:29-12.5x15
Edited by Jack C - 19 Dec 2016 at 2:53pm
ac720nut View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac720nut Quote  Post ReplyReply Direct Link To This Post Posted: 08 Nov 2016 at 3:14pm
While we're on the subject of turf tires I have a set with wheels that came off my 720 really nice condition $250 for set done need just need to move . Also set of tire chains for 31x15.50x15 tires $40
Edited by ac720nut - 08 Nov 2016 at 3:17pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote bamaboy Quote  Post ReplyReply Direct Link To This Post Posted: 10 Nov 2016 at 1:10am
PM sent!
Post Options Post Options   Thanks (0) Thanks(0)   Quote bamaboy Quote  Post ReplyReply Direct Link To This Post Posted: 18 Dec 2016 at 7:20pm
PM Sent!
Post Options Post Options   Thanks (0) Thanks(0)   Quote bamaboy Quote  Post ReplyReply Direct Link To This Post Posted: 21 Dec 2016 at 7:18pm
Still looking for a set of chains for 29/12-15 turf tires for my 616.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 28 Dec 2016 at 3:43pm
I purchased chains for my 720 2 years ago from Tire Chains R Us and am very pleased. I purchased 2 link chains, meaning there are more chains across you tires than 4 link. More chain contact with the ground for better traction and a better ride. I just called and gave them my tire size. I have the flotation tires so my size is different. i also recommend the center slack adjuster. Its basically a round ring with 4 springs that attach to 4 points on the tire chain. It keeps the chain tight while in use. My 720 was unstoppable
with these even with the 52" snowthrower up front.
