8070 Hydraulics
Smokey Joe View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Smokey Joe Quote  Post ReplyReply Direct Link To This Post Topic: 8070 Hydraulics
    Posted: 06 Nov 2016 at 5:09pm
I have an 8070 Tractor with Power Director it has a hydraulic whine to it, when you use loader it's terrible. Loader is hooked in back using remotes. A little history, I rebuilt the power director and torque limiter and cleaned the 30 years of rust out of floor of tractor. Also replaced gasket between rear end and transmission now i have a whine. 1500 rpms sounds good full throttle horrible and at idle, if you hit diff lock while using loader it gets even worse???
I didn't mess with anything from high pressure hydraulic side but seems like pump is stuck in pump position. Any body else have this issue before???
210,220,7010 AC,7020 AC,7040 AC,7045 Pedal Tractor, 8050& 8070 and Parts and Pieces of Many More!!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 06 Nov 2016 at 5:42pm
Sounds like a classic example of the hydraulic pumps high pressure hose going back to the 3point valve is touching the cab or diff lock pedal linkage.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Smokey Joe Quote  Post ReplyReply Direct Link To This Post Posted: 06 Nov 2016 at 6:00pm
I hope so, thats exactly what i told customer but he just doesn't want to believe me. I will investigate further thanks for reply!!!!!
tornado8070 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tornado8070 Quote  Post ReplyReply Direct Link To This Post Posted: 06 Nov 2016 at 7:33pm
Make sure the main suction line on he pump is tight and not sucking air. Takes a 2" wrench I beleive.
09’ DT205B, 08’ DT220A, 83' 8070 MFWD, 83’ 8070 85’ 8050 MFWD, 83' 8030, 82' 8010, 85’ 6080 MFWD, 84’ 6080, 79' 7020, 85' M3 RWD, 85' 920 diesel,AC C-50 forklift.
wekracer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wekracer Quote  Post ReplyReply Direct Link To This Post Posted: 07 Nov 2016 at 5:59am
I posted the same question 4-5 years ago with my 8050. Turned out to be a hydraulic line touching the bottom of the cab. Rerouted the line and it quit. Make sure no hydraulic lines touch the cab.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Smokey Joe Quote  Post ReplyReply Direct Link To This Post Posted: 07 Nov 2016 at 7:17am
Thanks for all the replies!!!!
