I've fallen and can't
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Topic: I've fallen and can't
    Posted: 05 Nov 2016 at 9:14pm
get up! Nothing runs like a Deere till it trips and falls over.
shameless (ne) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless (ne) Quote  Post ReplyReply Direct Link To This Post Posted: 05 Nov 2016 at 9:22pm
I hope he was able to jump clear! now...i'm wondering....how? do you suppose it would float the valves if he left it running? lol
CrestonM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 05 Nov 2016 at 9:26pm
Was he trying to pull out that tree?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 05 Nov 2016 at 9:37pm
Wow kinda scary and impressed that it would hook up enough to go all the way over
Edited by Mikez - 05 Nov 2016 at 9:39pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless (ne) Quote  Post ReplyReply Direct Link To This Post Posted: 05 Nov 2016 at 9:39pm
yep...i'll bet Creston is right, he was hooked to that tree to prolly make it fall one certain way....and it didn't!
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 05 Nov 2016 at 9:48pm
Nope.  The tree was on the ground. He was trying to cut off a limb and had the loader all the way up. Not sure if he was trying to keep the trunk from rolling or what. It flipped right back over after clearing a path with the neighbors skid loader, hooking a cable to it and tugging a bit with a 120HP FWA tractor.
 It has way less fuel in it now and probably not enough oil as he said it was running out the crankcase vent. Oh, and one less fender as the cast iron axle bracket is now 2 pieces. Seat is ruined and the steering wheel will need considerable help if it ever runs again.
Edited by CTuckerNWIL - 05 Nov 2016 at 9:50pm
Auntwayne View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Auntwayne Quote  Post ReplyReply Direct Link To This Post Posted: 05 Nov 2016 at 10:05pm
    Good time to change the oil pan gasket.
Dad always said," If you have one boy, you have a man. If you have two boys, you have two boys". "ALLIS EXPRESS"
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 05 Nov 2016 at 10:07pm
LOL He wasn't worried about the pan gasket. He was tickled to have it upright !
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless (ne) Quote  Post ReplyReply Direct Link To This Post Posted: 05 Nov 2016 at 10:45pm
and no one had a cigar to throw under it? lol
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 05 Nov 2016 at 10:52pm
A friend (older guy who has farmed forever) turned over a truck full of grain. Being a pretty big fellow, he was upside down, and kinda stuck. He was trying to figure out how to get out when gas started pouring on him. Afraid the truck might light up, he knocked out the windshield and crawled out.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 05 Nov 2016 at 10:53pm
Granddad tipped a B over plowing once. Hooked something and the tractor flipped over backwards.
