WD Hydraulic pump
Mike(SEIN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mike(SEIN) Quote  Post ReplyReply Direct Link To This Post Topic: WD Hydraulic pump
    Posted: 28 May 2010 at 7:18pm
I need a known good hydraulic pump for my WD. I have some bush hogging to do,tractor won't lift hog.I've had this pump off half a dozen times to shim unloader valve and seal all the leaks and I'm ready to try a different pump.
Chris/CT View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chris/CT Quote  Post ReplyReply Direct Link To This Post Posted: 28 May 2010 at 7:33pm
I have one on a WD-45 that was functioning awhile back.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 28 May 2010 at 7:49pm
When mine quit working, I found the shoulder on the bypass spool was broken off, letting it bypass all the time. It works great now with a new spool.
norm [ind] View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote norm [ind] Quote  Post ReplyReply Direct Link To This Post Posted: 28 May 2010 at 9:28pm
  we have some used pumps   1-574-342-4545
