D-12 sers.III starter
Marlyn nwia View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote Marlyn nwia Quote  Post ReplyReply Direct Link To This Post Topic: D-12 sers.III starter
    Posted: 28 May 2010 at 6:25pm
My starter would spin the engine very easily and fast.  Today it made a funny noise than a loud bang!!  The nose of the starter broke and the bendix came off the shaft of the starter.  Is this a bad omen?!!!  The engine turns easily with a srewdriver. It is not stuck tight!  How do I remove starter pieces from under the ring gear?  Must I split  the tractor to remove the starter pieces?  Reading this form-- I am wondering if someone could have placed the wrong starter in the D-12.  Any advice and encouragement would be appreciated!!!  Marlyn
DaveKamp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 28 May 2010 at 9:13pm
Hi Marlyn-
I'm not certain, but I BELIEVE there may be a clutch cover underside of the bellhousing, and you MAY be able to open that up for a look, and perhaps fish out most of the remains.  Obviously, if the engine still turns, the bendix remains aren't jamming it up.
If there IS a cover, but you can't see in at the proper angle, stick a digital camera up there and snap a few pictures, then look.  A magnet on a stick might be the ticket for fishin' out the larger pieces, although it might be a bit frustrating to maneuver.
norm [ind] View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote norm [ind] Quote  Post ReplyReply Direct Link To This Post Posted: 28 May 2010 at 9:22pm
  have seen a lot of them welded   if done properly    will work  1-574-342-4545
This page was generated in 0.116 seconds.
