hd14 allis Chalmers track parts
markat View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote markat Quote  Post ReplyReply Direct Link To This Post Topic: hd14 allis Chalmers track parts
    Posted: 03 Nov 2016 at 7:04pm
Is there any track parts for a hd14 crawler anywhere? We are trying to repair one and are finding it difficult to find parts. Is there anything that is close where a guy could make something work? Any help would be appreciated. Thanks.
CAL(KS) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 04 Nov 2016 at 5:29am
zimmerman tractor in versailles MO  would have things like rollers and truck wheels as they have some salvage hd10s.  i dont believe they have any 14s but it wouldnt hurt to call.
 General Gear in Idaho has some salvage 14s
someone may know of something closer to you.  on second thought im not 100% sure rollers etc are same on 14
Edited by CAL(KS) - 04 Nov 2016 at 5:49am
shameless (ne) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless (ne) Quote  Post ReplyReply Direct Link To This Post Posted: 11 Nov 2016 at 2:08pm
thought I read in here that a lot of present CAT track parts are the same? might be wrong, but I would investigate it!
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 12 Nov 2016 at 11:55am
What pitch rails on it? I can find nothing to base on as to pitch so trouble converting.
Post Options Post Options   Thanks (0) Thanks(0)   Quote markat Quote  Post ReplyReply Direct Link To This Post Posted: 12 Nov 2016 at 2:20pm
How would you find out the pitch on it?
donoman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote donoman Quote  Post ReplyReply Direct Link To This Post Posted: 12 Nov 2016 at 3:30pm
The new spec for HD14 pitch is 7.850 max wear 8.037 HD10 run the same tracks so maybe you could run 8"pitch chains
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 12 Nov 2016 at 3:43pm
That would be Cat 8.0 with smaller bushing Diameter?
Post Options Post Options   Thanks (0) Thanks(0)   Quote donoman Quote  Post ReplyReply Direct Link To This Post Posted: 12 Nov 2016 at 10:39pm
possibly get whatever 8"pitch chains you can get and then weld and shape the sprocket teeth to suit, there is no specs in the workshop manual for chain width and bushing size so you would need to check roller width, with 8" pitch you will find something
Post Options Post Options   Thanks (0) Thanks(0)   Quote donoman Quote  Post ReplyReply Direct Link To This Post Posted: 14 Nov 2016 at 1:22am
HD16 chains have the same pitch with a max wear of 8.031
