Brought home what was supposed to be a B
Glockhead SWMI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Glockhead SWMI Quote  Post ReplyReply Direct Link To This Post Topic: Brought home what was supposed to be a B
    Posted: 28 May 2010 at 2:15pm
Ended up being a C with a B wishbone axle. Not sure if I want this. I really need something narrower to cultivate with. Lots of good parts here though.
Going ot pick up one of the WD's Sunday. Going to look at an unstyled WC also. I'll post pics soon.
Dick L View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 28 May 2010 at 2:28pm
The old style B cultivators will work on the C the same as the B when you have the wider front. They bolt to the torqie tube over the inspection hole and on the foot rest. You can set the rims in close to the fenders and be quite narrow. You probly need to swap sides with the rims to keep the tread going forward. It would just be the looks because you won't need a lot of traction cultivating.
DREAM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DREAM Quote  Post ReplyReply Direct Link To This Post Posted: 28 May 2010 at 5:01pm
That should work just fine. Like DickL said, just take the left wheel assembly with hub off and swap to the right side and vice-versa. No need to break the concentrics loose or remove the rim from the center. I had to spread mine out to mount the 80 series cultivators with the rear middle plows. The rear lift arm lower support will not clear the wheels when turned in. I am set up for 36" rows, and like the room there. If space is a problem, the narrower rows (30"?) that you can get with the B will work fine. I just like the narrow front on the C better for cultivating. One less thing I have to worry about running over something with.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Glockhead SWMI Quote  Post ReplyReply Direct Link To This Post Posted: 28 May 2010 at 5:26pm
Here is a picture. I wonder what the frame that the home made blade is hanging off of was originally for?
http://i218.photobucket.com/albums/cc308/jessz1/IMG_9445.jpg
Post Options Post Options   Thanks (0) Thanks(0)   Quote Glockhead SWMI Quote  Post ReplyReply Direct Link To This Post Posted: 29 May 2010 at 7:17am
My picture is not working properly...
Edited by Glockhead SWMI - 29 May 2010 at 7:38am
GlenninPA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GlenninPA Quote  Post ReplyReply Direct Link To This Post Posted: 29 May 2010 at 8:10am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Glockhead SWMI Quote  Post ReplyReply Direct Link To This Post Posted: 29 May 2010 at 8:22am
Thanks Glenn.
Every time I try and upload a photo, it says it is too big or the server is busy or??? I do not like the photo deal on this site.
This page was generated in 0.057 seconds.
