185 Front Spindles
ChrisS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ChrisS Quote  Post ReplyReply Direct Link To This Post Topic: 185 Front Spindles
    Posted: 01 Nov 2016 at 12:50pm
Parts book calls out a 10 degree front spindle P/N 70270044 ($516.00) and a 12 degree front spindle P/N 70270038 ($204.00). Is this 2 degrees the camber angle? What was AC's engineering reason for the small difference and why such a price difference between the two?
JoeO(CMO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeO(CMO) Quote  Post ReplyReply Direct Link To This Post Posted: 01 Nov 2016 at 1:01pm
allows a wider tire to be used on the 12 deg.
Edited by JoeO(CMO) - 01 Nov 2016 at 1:02pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote ChrisS Quote  Post ReplyReply Direct Link To This Post Posted: 04 Nov 2016 at 9:17am
What was the standard spindle degree 10 or 12 and what was the standard tire/wheel size? How big of a tire can you go with if you have the 12 degree spindle?
Thanx
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 04 Nov 2016 at 9:22am
I have 11l x 15s on mine. Not sure which spindle is on it, but that is about the limit of clearance. HTH Tracy
Post Options Post Options   Thanks (0) Thanks(0)   Quote Skyhighballoon(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 04 Nov 2016 at 8:19pm
I have 10.00x16's on my 180 but the wheel dish is reversed to change the offset.  No issue with spindle clearance.   Mike
1968 Gleaner EIII w 10' & 330
1969 180 gas
1965 D17 S-IV gas
1963 D17 S-III gas
1956 WD45 gas NF PS
1956 All-Crop 66 Big Bin
Eldon (WA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Posted: 04 Nov 2016 at 10:38pm
Most 15" wide rims need to be reversed to work. Are you sure they aren't talking about the length? The tall spindles are 2" longer.
ALLIS EXPRESS!
This year:
