Cab Doors
Tbone95 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Topic: Cab Doors
    Posted: 01 Nov 2016 at 12:00pm
Will a cab door from an "early" 7060 (maroon belly) fit a 7045?
Dans 7080 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dans 7080 Quote  Post ReplyReply Direct Link To This Post Posted: 01 Nov 2016 at 12:29pm
Yes. The latches are different on the inside but it will work.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 02 Nov 2016 at 2:58pm
Can anyone else confirm this? Sorry Dans, not dissing you at all, just the way I have it figured is a lot of time to get this and have it be wrong.
Thanks all....
ryan(IN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ryan(IN) Quote  Post ReplyReply Direct Link To This Post Posted: 02 Nov 2016 at 3:20pm
In the parts books they show different part numbers for maroon belly and black belly (>6001 s/n). The difference may just be the handle and latch on the inside. I think they would still interchange though.
ryan
1984 8070 FWA,1979 7060,1975 7040,1971 190,1960 D-17D,1957 D-14, 196? D-19G, 1975 5040,1971? 160,1994 R62
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dans 7080 Quote  Post ReplyReply Direct Link To This Post Posted: 02 Nov 2016 at 6:38pm
No problem. I usually like a few opinions too. I have a black belly 7080 door that I would get rid of. Good glass typical rust on the bottom. I'm in SWOH.
WD45Diesel57 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WD45Diesel57 Quote  Post ReplyReply Direct Link To This Post Posted: 02 Nov 2016 at 8:53pm
I'm putting a door off a 7040 maroon on my 7020 door frame is the same just need to change out the latch
1-B's, 2-C, 2-CA's,2-WF, 1-WC,1-G, 3-WD's, 2-WD45, 1-RC, 1-D17 Diesel, 1-D14, 2-D15,1-D17 row crop,1-D19 gas and All Crop 40,60,66,72,90 and 100
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 03 Nov 2016 at 6:26am
Thank you all!
