180 or 185 to build
graveyard View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote graveyard Quote  Post ReplyReply Direct Link To This Post Topic: 180 or 185 to build
    Posted: 31 Oct 2016 at 9:44pm
How light can u get a 180 or 185 and what would be a good motor to build for a 7000 lb 414 cubic inch limit open class
Post Options Post Options   Thanks (0) Thanks(0)   Quote graveyard Quote  Post ReplyReply Direct Link To This Post Posted: 31 Oct 2016 at 9:49pm
Forgot to add it will be gas. A 292 combine motor?
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 31 Oct 2016 at 10:27pm
292 Combine motor is a GM engine.  I presume you are looking for an Allis engine, in this case the 301 would be your only possibility for a gasser.
bsallis180 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bsallis180 Quote  Post ReplyReply Direct Link To This Post Posted: 01 Nov 2016 at 7:42am
There is a 190 for sale privately . It's 414 proven winner roller cam Aircraft carburetor all the best stuff. Think 18.4x38s. It pulled naturally aspirated modified stock class. 7000 or 7500 would sale just the motor I'm sure
Post Options Post Options   Thanks (0) Thanks(0)   Quote graveyard Quote  Post ReplyReply Direct Link To This Post Posted: 01 Nov 2016 at 2:45pm
Is it not true that a 292 actually came out in some of the gleanor combines? I was told that. what can u build a 301 up to?
Larry W. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Larry W. Quote  Post ReplyReply Direct Link To This Post Posted: 01 Nov 2016 at 4:48pm
180 would be a great candidate for the class, build a 301 up. They can go well over 500 ci if you want to go that big. 415 gas would be a very reliable strong settup. Mesage me if you like , I've built them at 410, 450 and 526
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 01 Nov 2016 at 5:56pm
Yes many Gleaner combines used a GM engine in later years.  Getting it to fit in a 180 or 185 frame would take some creativity...
Post Options Post Options   Thanks (0) Thanks(0)   Quote graveyard Quote  Post ReplyReply Direct Link To This Post Posted: 01 Nov 2016 at 5:58pm
Larry w thanks just looking and planning right now . thanks for the offer I will get in touch . my d 17 was just a little undersized for the 7000 lb class. actually didn't run out of power but way too much weight on it. over 2300 lbs
bradley6874 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bradley6874 Quote  Post ReplyReply Direct Link To This Post Posted: 01 Nov 2016 at 6:33pm
Here's a thought if you can use a combine motor from a gleaner in a Ac tractor and say it's ok per your rules then put a 350 chevy in it and say it came off a m or l gas combine
Post Options Post Options   Thanks (0) Thanks(0)   Quote graveyard Quote  Post ReplyReply Direct Link To This Post Posted: 01 Nov 2016 at 9:05pm
the farmall guys do it with the international truck motors in the 460 and 560's lol
This page was generated in 0.079 seconds.
