B-110 questions
Orange4ever View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orange4ever Quote  Post ReplyReply Direct Link To This Post Topic: B-110 questions
    Posted: 31 Oct 2016 at 6:52pm
Was at a local auction today and picked up a B-110 with mower deck. Doesn't run but engine is free and probably only needs minor work. Is there anything I need to look for or watch out for? It came from bowling green and was used at a car dealer ship for years, and was replaced and put in the owners basement until now. The carburetor was changed at one time and we've ordered a new one.
If you want a man to be a successful farmer, give him a Allis Chalmers tractor. If you want him to be a successful mechanic, give him a John Deere
ACmowerguy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACmowerguy Quote  Post ReplyReply Direct Link To This Post Posted: 31 Oct 2016 at 8:56pm
Bowing Green, MO? If the new carb is one of the new knock-offs from eBay the air cleaner may not fit correctly. You can get the parts to make the original like-new for less than the Chinese carb. Any pictures of this B-110? They are a good tractor. I have two of them.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orange4ever Quote  Post ReplyReply Direct Link To This Post Posted: 01 Nov 2016 at 8:03pm
[/IMG]
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACmowerguy Quote  Post ReplyReply Direct Link To This Post Posted: 01 Nov 2016 at 8:07pm
Wow!!! Very nice. That one would detail up great!! Its a later model as it doesn't have the push button start.
Edited by ACmowerguy - 01 Nov 2016 at 8:08pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 01 Nov 2016 at 10:35pm
Yea looks in good shap. Is there something sticking out the front.
ac720nut View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac720nut Quote  Post ReplyReply Direct Link To This Post Posted: 02 Nov 2016 at 4:15am
Deffinately nice , should really cleanup nice.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orange4ever Quote  Post ReplyReply Direct Link To This Post Posted: 02 Nov 2016 at 4:41pm
I do not know what was on the front of it, yes bowling green MO
macvette View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote macvette Quote  Post ReplyReply Direct Link To This Post Posted: 03 Nov 2016 at 10:15pm
Sure looks nice.
split51 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote split51 Quote  Post ReplyReply Direct Link To This Post Posted: 03 Nov 2016 at 10:23pm
Nice looking machine. Looks to still have the original tires.
1929 20-35 sn17662
B1 w/snow blade
B10 w/sickle mower
B110 w/mower deck
B110 w/tiller
B112 w/grader blade
B210 w/plo
LionelinKY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LionelinKY Quote  Post ReplyReply Direct Link To This Post Posted: 04 Nov 2016 at 7:36am
I can't see his picture but should be crankshaft sticking out through the grille. Pulley mounts to that shaft to drive front mount implements-mainly snowblower. Probably only needs a set of points to get her back running as long as it has good compression. The old B&S is a bulletproof engine. Matches the rest of the machine. New points, clean carb, and fresh gas should have her barking again.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 04 Nov 2016 at 8:51am
Oh yea the picture disappeared. No it wasn't the crank shaft. It was a side view picture and looked like a bracket of some sort. I just never see anything like that before.
