D15 with unknown engine
CBMike View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CBMike Quote  Post ReplyReply Direct Link To This Post Topic: D15 with unknown engine
    Posted: 31 Oct 2016 at 5:39pm
I recently purchased a 1961 D15. Got it home and soon discovered that all is not as it appears. It started when I saw that someone had torched a notch into the front bracket that the engine mounts to.
Why would anyone do that unless it was not the original engine.
Then when I went to order a new manifold gasket, a D15 didn't seem correct. The bolt pattern matches that of a B/C/CA pattern, and the manifold itself looks like a B/C/CA but the previous owner had the metal type cups on the manifold that match a WC/WD/WD45 D17 and 170.
So I started researching the number cast into the block of the engine, AM 2916 35
This number does not seem to match any B/C/CA numbers as they end in a 30 for 1958.
There is another number stamped on the flange of the engine where it bolts to the torque housing. CR 50468 PA. I've had no luck researching this number.
I've added another photo of the right side of engine to help out.
Any help I could get on identifying the engine that is in this tractor would be greatly appreciated. I figure it runs so good that I might as well live with it. I'm only going to use to mow and maintain a 4 acre food plot and some trails but want to make sure that when servicing it that I get the correct specs on it.
CrestonM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 31 Oct 2016 at 5:44pm
Looks like an earlier engine to me, since it has a mag.
But like you say there shouldn't be a torch cut in the bracket.
Edited by CrestonM - 31 Oct 2016 at 5:45pm
DennisA (IL) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DennisA (IL) Quote  Post ReplyReply Direct Link To This Post Posted: 31 Oct 2016 at 6:01pm
Engine is out of an "RC" I'm thinking.
Thanks & God Bless
Dennis
Bill Deppe/AC Salvag View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill Deppe/AC Salvag Quote  Post ReplyReply Direct Link To This Post Posted: 31 Oct 2016 at 7:32pm
My guess is from a B or C model. RC's didn't have the generator bosses. Also not a D series engine due to not have the opening under the magneto area for the power steering pump
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 31 Oct 2016 at 9:51pm
No D15s ever had magneto's on them either (except for this one).  B and C engines are cheap and plentiful, so that is my guess.  Considerably less horsepower too.
WD45Diesel57 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WD45Diesel57 Quote  Post ReplyReply Direct Link To This Post Posted: 31 Oct 2016 at 10:11pm
That is a power unit motor off of a combine or baler, those motor serial numbers start with prefix CR, I have that same motor in my B!
1-B's, 2-C, 2-CA's,2-WF, 1-WC,1-G, 3-WD's, 2-WD45, 1-RC, 1-D17 Diesel, 1-D14, 2-D15,1-D17 row crop,1-D19 gas and All Crop 40,60,66,72,90 and 100
Post Options Post Options   Thanks (0) Thanks(0)   Quote CBMike Quote  Post ReplyReply Direct Link To This Post Posted: 01 Nov 2016 at 9:59pm
Do you know what kind of horsepower it is putting out and if i can get a service manual for it?
Post Options Post Options   Thanks (0) Thanks(0)   Quote WD45Diesel57 Quote  Post ReplyReply Direct Link To This Post Posted: 01 Nov 2016 at 10:10pm
I would say high 20's they rev significantly higher rpms
Chalmersbob View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chalmersbob Quote  Post ReplyReply Direct Link To This Post Posted: 01 Nov 2016 at 10:16pm
Same engine as on a B, C, or CA. Same service manual. LOL Bob
4 B's, 1 C's,3 CA's, 2 G's WD, D14, D15, B-1, B10, B12, 712S,
Post Options Post Options   Thanks (0) Thanks(0)   Quote CBMike Quote  Post ReplyReply Direct Link To This Post Posted: 01 Nov 2016 at 10:25pm
Thank you
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 02 Nov 2016 at 2:04am
I have an AC G, B, C, and CA shop manual plus a B military manual (possibly IB) hidden on my web server.
http://www.geraldj.networkiowa.com/Trees/Allis-Chalmers-G-B-C-CA-Service.pdf
http://www.geraldj.networkiowa.com/Trees/BMilitary.pdf
Gerald J.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 02 Nov 2016 at 7:05am
If you have the manifold for it it will have a petcock if it's a combine engine.
rpropst View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rpropst Quote  Post ReplyReply Direct Link To This Post Posted: 02 Nov 2016 at 8:42am
It is a B or CA arrow head block \arrow head cast in to block just ahead of the dipstick\ 1951 or later.
1950 snap coupler B 1948 WD 1951Ca 1952B 1952adjustable axel B
Post Options Post Options   Thanks (0) Thanks(0)   Quote CBMike Quote  Post ReplyReply Direct Link To This Post Posted: 02 Nov 2016 at 10:03pm
Thank you very much
Post Options Post Options   Thanks (0) Thanks(0)   Quote CBMike Quote  Post ReplyReply Direct Link To This Post Posted: 02 Nov 2016 at 10:04pm
The manifold does have a petcock on it. Thanks for the info
Post Options Post Options   Thanks (0) Thanks(0)   Quote CBMike Quote  Post ReplyReply Direct Link To This Post Posted: 07 Nov 2016 at 9:34pm
I'd like to thank everyone for their taking time out to help me with the above post. A special shout out to Gerald J for info manuals. As I continue to clean this machine up, add a part here and there, and some fresh paint, I'm sure I will have more questions.
