AllCrop Cylinder Bearing Install Update
Auntwayne View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Auntwayne Quote  Post ReplyReply Direct Link To This Post Topic: AllCrop Cylinder Bearing Install Update
    Posted: 30 Oct 2016 at 10:10pm
Bearings were installed today.  However, we did not have time to install the cylinder into the combine.  So, here are the updated pictures.  I did not write down bearing #'s.  Hoped that they would show clearly in pictures.  Post #'s tomorrow.  A rather large "slug" was run thru the combine by PO and bent cylinder cover, so we removed to straighten.  You do not have to.  We also had to make our own shims, not sure how/why you lose them.
Dad always said," If you have one boy, you have a man. If you have two boys, you have two boys". "ALLIS EXPRESS"
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pat the Plumber CIL Quote  Post ReplyReply Direct Link To This Post Posted: 30 Oct 2016 at 10:36pm
This chit is a lot of fun aint it ? Looks good Duane . That should one smooth running all crop when finished . Are those soybeans still going to be standin when you get it all back together ?
Allis dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis dave Quote  Post ReplyReply Direct Link To This Post Posted: 31 Oct 2016 at 6:41am
Great pictures. I have to put in cylinder bars in my 72 one of these days.
CrestonM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 31 Oct 2016 at 7:41am
I need to justify buying cylinder bars for 3 All-Crops one of these days....whew!
KenBWisc View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KenBWisc Quote  Post ReplyReply Direct Link To This Post Posted: 31 Oct 2016 at 9:52am
Great looking rubber on those bars!
mruhlig77 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mruhlig77 Quote  Post ReplyReply Direct Link To This Post Posted: 31 Oct 2016 at 11:47am
Allis dave..thanks for the info ... wish my 72s were that clean...Mark , your neighbor in Indiana....
Post Options Post Options   Thanks (0) Thanks(0)   Quote Auntwayne Quote  Post ReplyReply Direct Link To This Post Posted: 31 Oct 2016 at 7:52pm
    Beans were combined Saturday Patrick. Big problem with Photobucket last night, took 3 1/2 to get pictures on. That is also why you are seeing doubles and maybe triples and other pictures not posted. If anyone wants the bearing numbers PM either me or Ryan, they are available by bearing distributors every where (not rare).
Dmpaul89 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dmpaul89 Quote  Post ReplyReply Direct Link To This Post Posted: 31 Oct 2016 at 8:51pm
nice work. neat seeing the cylinder out like that.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 31 Oct 2016 at 9:03pm
Cool! So when I have to pull mine one of these days, what are the steps to get everything off on the drive end? Sure seems like a tight spot to try to do much.
Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote Auntwayne Quote  Post ReplyReply Direct Link To This Post Posted: 31 Oct 2016 at 9:40pm
    Creston, not hard at all. Not as tight as it looks, just have a buddy help slide the cylinder out and carry it to your saw horses or tailgate. Helps to have a lot of emory cloth and like standing in the same spot for several hours.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Auntwayne Quote  Post ReplyReply Direct Link To This Post Posted: 31 Oct 2016 at 9:43pm
    PS Creston, Allis engineers were great at their jobs. They knew that the cylinders had to be removed, maybe several times over the combines life. So, they made removing them as easy as possible.
