WD45 FWA
CrestonM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Topic: WD45 FWA
    Posted: 30 Oct 2016 at 10:00pm
This isn't mine, but I wish it was! I think it looks really cool!
plummerscarin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote plummerscarin Quote  Post ReplyReply Direct Link To This Post Posted: 30 Oct 2016 at 10:30pm
Ooohh I like that. I bet that would look good under Dad's 6 cylinder gas engine swap!
Dan73 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dan73 Quote  Post ReplyReply Direct Link To This Post Posted: 30 Oct 2016 at 10:50pm
Now that is a kit you could sell. I would love one for my d15 loader.
BillinAlberta View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BillinAlberta Quote  Post ReplyReply Direct Link To This Post Posted: 30 Oct 2016 at 11:01pm
How is the front axle driven?
Are there any D17's like this?
That is really great looking.
JC-WI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JC-WI Quote  Post ReplyReply Direct Link To This Post Posted: 30 Oct 2016 at 11:25pm
Can you imagine what a 170 or a 180 would look like with that set up on it...WOW!!!
Mrgoodwrench View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mrgoodwrench Quote  Post ReplyReply Direct Link To This Post Posted: 30 Oct 2016 at 11:38pm
Wow am180 or 190 Fwa would be awesome
There are 3 ways to do job GOOD, FAST, CHEAP. YOU MAY CHOOSE 2. If its FAST & CHEAP it won't be GOOD, if it's GOOD & CHEAP it won't be FAST, and if its GOOD & FAST it won't be CHEAP!!!!
AJ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AJ Quote  Post ReplyReply Direct Link To This Post Posted: 30 Oct 2016 at 11:51pm
If I remember right that a John Deere front end that was modified to fit the front of that.
Can't fix stupid
Allis dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis dave Quote  Post ReplyReply Direct Link To This Post Posted: 31 Oct 2016 at 6:37am
You could drive through almost anything with that!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 31 Oct 2016 at 6:47am
Wow! That would turn a 45 into a real work horse!
truckerfarmer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote truckerfarmer Quote  Post ReplyReply Direct Link To This Post Posted: 31 Oct 2016 at 6:51am
It appears to be driven by the PTO.
Gotta wonder if it has enough power to actually do anything though? Just guessing here but, gotta think it takes 10-15 HP just to run the front axle. A good running WD45 puts out 45HP. Take away 1/3 of that, and there ain't much left for pulling implement.
All in all, it is neat looking though.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis dave Quote  Post ReplyReply Direct Link To This Post Posted: 31 Oct 2016 at 6:59am
That's why it'd be perfect for the 6 cyl swap. You get some extra power and I bet since it'd be spread through the PTO and rear end you wouldn't hurt anything.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dan73 Quote  Post ReplyReply Direct Link To This Post Posted: 31 Oct 2016 at 7:54am
I always wondered if you could find an ac elenco kit. I know that they where made for more then the fords. I have seen some on IH. But never on an AC. I can tell you the Ford 800 serries with one of those kits make a great improvement for a loader or plow tractor.
Lynn Marshall View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lynn Marshall Quote  Post ReplyReply Direct Link To This Post Posted: 31 Oct 2016 at 8:49am
littlemarv View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote littlemarv Quote  Post ReplyReply Direct Link To This Post Posted: 31 Oct 2016 at 8:52am
If you take into account 15 horse for the front axle, you'd be right back to what a WD had for horsepower......
The mechanic always wins.
Randy WI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Randy WI Quote  Post ReplyReply Direct Link To This Post Posted: 31 Oct 2016 at 9:11am
Don't think that PTO drop gear box will hold up . I had one with that gear box was blown out running 9 foot haybine in heavy clover had to replace the torque tube. Randy
Don(MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 31 Oct 2016 at 9:24am
Horse power is up with a G-226 like used in the D17/E Gleaner and the WC trans in front of the WD45 trans with front axle power is coming from the box coming off the back of the WC trans not the PTO box.
This is a 10 on the cool scale.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis dave Quote  Post ReplyReply Direct Link To This Post Posted: 31 Oct 2016 at 10:13am
I'd like to see it in person and see just exactly how they got all that linked together. I'd have to put a set of duals on it of course.
Dmpaul89 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dmpaul89 Quote  Post ReplyReply Direct Link To This Post Posted: 31 Oct 2016 at 10:29am
you have a hard time getting those 45hp to the ground anyway. that was a big gripe of farmers back then the extra hp doesnt help if the tires just slip. now this is a good way to utilize the power
Tbone95 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 31 Oct 2016 at 10:47am
My very first thought was similar to that above, with the parasitic horsepower it wouldn't help that much. But then, I think of my MFWD tractor. It isn't all that high of horsepower, I think about 70. But that's irrelevant. My experience, if you are driving in a field, relatively loose or whatever, when you turn the FWA on, the engine actually picks up, in other words, runs easier.
Now that's compared to it pushing the "big" tires through versus them pulling, where the original wheels the 45 had wouldn't be such a draw.
So, IDK.
But, no matter, pushing any tires takes some HP, so it's not a comparison from 0. Anyway, looks good and cool project.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dan73 Quote  Post ReplyReply Direct Link To This Post Posted: 31 Oct 2016 at 6:12pm
Pushing the stock tires in mud takes alot of power if they are plowing.   Proved that to a friend with a farmall M and a loader. He kept saying it was short on power cleaning his barn finial got him to put flotation tires on the front and he couldn't believe it was the same tractor.   So it all depends.   But plowing or using a loader i bet it actually uses the power better.
