loaded tires
john2189 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote john2189 Quote  Post ReplyReply Direct Link To This Post Topic: loaded tires
    Posted: 30 Oct 2016 at 1:46pm
Ive seen that some use beet juice, windshield washer fluid, old antifreeze instead of calcium.  what is wrong with using plain water? I know it will freeze, but what would that hurt?
john
'41 Allis B
'45 Allis B
'49 Farmall Cub
'72 IH Cub
Dmpaul89 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dmpaul89 Quote  Post ReplyReply Direct Link To This Post Posted: 30 Oct 2016 at 2:46pm
i would think ice could split the rim pretty easily and if it didnt you would have one heck of a rough ride from the air bubble thats left when filling (they dont get filled completley with fluid) need that air pocket to compress and absorb shock.    people do it in the south all the time. gotta watch that if you ever buy a tractor from deep south
Edited by Dmpaul89 - 30 Oct 2016 at 2:49pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote john2189 Quote  Post ReplyReply Direct Link To This Post Posted: 30 Oct 2016 at 2:54pm
ok i guess it would be a solid ride
'41 Allis B
'45 Allis B
'49 Farmall Cub
'72 IH Cub
Stan R View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stan R Quote  Post ReplyReply Direct Link To This Post Posted: 30 Oct 2016 at 3:11pm
I bet a high speed drive would be fun though.
JoeM(GA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeM(GA) Quote  Post ReplyReply Direct Link To This Post Posted: 30 Oct 2016 at 3:18pm
you never fill them past 75 percent full anyway, tires need the other room to make their "footprint" Even here in Georgia, water in a tire will freeze, if you've filled it almost full to full, you will lose a tire, and or bend a rim when the ice expands and there's no air to compress. lots of people here will fill them then drain in the fall (you hope they don't get caught one night with a surprise freeze) but you never will get it all out. and that small bit will freeze even easier. That sharp edge of that piece of ice will lose it's grip and tumble and flop around and the sharp edge will cut a tube to ribbons and even cut a tire.
 I'm guilty of doing it too, just "drained" mine but I always add a gallon or so of RV antifreeze in to treat what remains.
info on filling, the idea hasn't changed from my 1941 WC manual other than the calcium chloride!
Allis Express North Georgia
41 WC,48 UC Cane,7-G's,
Ford 345C TLB
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dmpaul89 Quote  Post ReplyReply Direct Link To This Post Posted: 30 Oct 2016 at 3:27pm
Believe me if it was practical to fill with water everyone would be doing it. I'd just spend the money on a quality ballast.
Dans 7080 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dans 7080 Quote  Post ReplyReply Direct Link To This Post Posted: 30 Oct 2016 at 4:28pm
Fluid doesn't compress. If completely filled it would be like riding on steel. Water expands when it freezes something will give. I kinda doubt it would split the rim but I bet you'd have a nice tire left come spring. Calcium weighs more than water anyway.
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 30 Oct 2016 at 5:10pm
Calcium chloride is heavier than any of the alternatives including water, but it rusts steel rapidly when it leaks and it WILL leak. Some of the alternatives like beet juice are a lot more expensive but don't rust steel.
Gerald J.
HD6GTOM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HD6GTOM Quote  Post ReplyReply Direct Link To This Post Posted: 30 Oct 2016 at 5:24pm
John DONT do it. I have gone out and unbolted frozen tires from tractors, brought them to the tire shop and let them thaw out - usually takes about a week to do. You cannot operate the tractor with frozen tires. It is tough on tires and old tire men!
shameless (ne) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless (ne) Quote  Post ReplyReply Direct Link To This Post Posted: 30 Oct 2016 at 5:34pm
was at a consignment sale one day (in winter) and someone bought a tractor and started out driving it home, in about an hour, he came back BLOODY! his head looked like someone worked him over real good. come to find out, when he took off down the highway in road gear the tractor started bouncing wildly, throwing him around in the cab, hitting his head on about everything! someone had filled part of the rear tires with water and it froze. the auctioneers put the tractor in their shop with knipcos facing the tractor, then they took the guy to the hospital. they'd take the valve stem off and watch the melted water blast out of the tire. it took about 30 hours to get most of it out.
DennisA (IL) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DennisA (IL) Quote  Post ReplyReply Direct Link To This Post Posted: 30 Oct 2016 at 5:56pm
Gerald J.
 I have had calcium in my tires for 16-17 yrs. with no leaking. All it takes is a little maintenance. Just change the valve core very 2 yrs.
Thanks & God Bless
Dennis
Rayhowling View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rayhowling Quote  Post ReplyReply Direct Link To This Post Posted: 30 Oct 2016 at 6:59pm
My son bought a new tractor and put beet juice in and no tube. The beet juice is about the cost of a tube. I have had a couple of rims rust around the valve stem and now we only have beet juice in the loader tractor with 16.9 X 34 tires. Some tire repair shops will not work on tires that have beet juice in them, too messy.
Bill Long View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill Long Quote  Post ReplyReply Direct Link To This Post Posted: 30 Oct 2016 at 7:20pm
When we sold them calcium chloride was the accepted filler.  In fact, sometimes we "jiggered" the fill amount and filled to 80% of the tire.
Since I had to do most of our tire changes i HATED working with it.  However, it was heavy and we could pull a lot with no wheel weights.  Course nowadays it is not good.
I do agree with Gerald J.  with proper maintenance it works very well.
Do not repeat not use water.  However, you could mix it with some salt which would act as anti freeze.  We had a mechanic who worked with us from Texacana Arkansas and he filled them with water.  When they froze he would hit the tire in various places with a sledge to break it up.  Claimed it worked well.
Good Luck!
Bill Long
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 30 Oct 2016 at 7:34pm
My MF-135 had CaCl in the rear tires. A sidewall developed a 2" long crack and one day pinched the tube and it sprayed me and the tractor. My jeans that night stood on their own and the tractor rusted instantly. Cost extra to get the CaCl pumped out to replace the tires and I haven't put any back.
Gerald J.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DennisA (IL) Quote  Post ReplyReply Direct Link To This Post Posted: 30 Oct 2016 at 8:02pm
Sounds like a big mess. Yes when you have something catastrophic happened such is that it is imperative that the equipment gets hosed down immediately.
Thanks & God Bless
Dennis
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 30 Oct 2016 at 10:55pm
The rusting through the aluminum paint on the drive housings was in seconds. I was about 12 miles into a 16 mile trip hauling my three point back hoe to a welding shop for repairs and updating. No water available to wash it. Fortunately there was a coop tire shop less than a block from the welding shop and they took out the CaCl right away and in a couple days I found and bought some new tires and that tire shop put them on with new tubes. And it took the welding shop that long to get to the back hoe welding.
Gerald J.
victoryallis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote victoryallis Quote  Post ReplyReply Direct Link To This Post Posted: 30 Oct 2016 at 11:08pm
Gerald J.
I call bull.
I work in a plant that manufactures Calcium Chloride. The liquid end of our plant is original 1942 construction. Properly managed it does not rust stuff out.   One key is to wash any exposed metal with HOT water immediately.
Eldon (WA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Posted: 31 Oct 2016 at 12:13am
I bought a tractor out of California a few years ago. I went to move it in the spring and I thought the final drives were shot it was making some really bad noises. Finally figured out it was half thawed ice in the rear tires. Fortunately the tires were crap anyway...
ALLIS EXPRESS!
This year:
wayneIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wayneIA Quote  Post ReplyReply Direct Link To This Post Posted: 31 Oct 2016 at 12:47am
Dad recalled when they got tractors out of the South at the implement and they either forgot to drain the tires, or it froze before they could drain them.  They would put two "torpedo" heaters on the 18.4x34 tires on a 190 and it  would take about 2 days to thaw them he said.  He did say it was about the roughest ride you'd never want too since on the frozen side each lug was rock solid when it hit the ground.  Then when the air pocket hit the tractor would tip to that side since the air gave some cushion.  They onetime got a 190 in though that had the rear tires filled with powdered lead.  They have no idea where the person got the powdered lead, or even how they got it into the tire.  I personally filled all my tires with a product called bio tire, it is glycerin left from making bio-diesel.  It weighs about the same as calcium or the beat juice, but doesn't corrode like the calcium, and is thinner to pump in cold weather and not sticky like the beet juice.  I figured up what it cost me to replace rims on the tractors that had rotted, and what the fluid cost was about the same as what a set of rims cost.
alleyyooper View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote alleyyooper Quote  Post ReplyReply Direct Link To This Post Posted: 31 Oct 2016 at 7:23am
I buy a tractor for my collection and once home the first order of business is to drain all the chloride out I can get out with out a pump.
Don't need the extra weight to trailer to shows and if I am going to pull one is easier to adjust the tractor weight with wheel and suit case weights.
   Al
Gary Burnett View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 31 Oct 2016 at 7:32am
Gerald J.
The problem comes when the tube starts leaking somewhere other than the valve stem and the rim will be rusted thru before you realize there is a problem, seen that happen many times.
Post Options Post Options   Thanks (0) Thanks(0)   Quote victoryallis Quote  Post ReplyReply Direct Link To This Post Posted: 31 Oct 2016 at 11:19am
   Al
Don't value your life?   Fluid in tires creates a lower center of gravity that other forms of weight. Tire con man talked my uncle into pumping the fluid out of his 7000 to provide better tire flex now a 6080 with bias tires can pull as much or more.
This page was generated in 0.354 seconds.
