trans noise when in nutral |
john2189
Joined: 11 Sep 2009 Location: Minerva,Ohio Points: 307 |
Topic: trans noise when in nutralPosted: 30 Oct 2016 at 1:43pm |
I think i have a bearing going bad in a B transmission. can I change it thru the shifter plate on the side? or do I have to pull the finals and remove trans from the torque tube? I dont hear the noise when its in gear and the tractor moving.
John
'41 Allis B
'45 Allis B '49 Farmall Cub '72 IH Cub |
Alberta Phil
Joined: 13 Sep 2009 Location: Alberta, Canada Points: 3953 |
Posted: 30 Oct 2016 at 2:49pm |
Sounds like it might be the throw out bearing. Easiest is just split the tractor at engine/bellhousing.
john2189
Posted: 30 Oct 2016 at 2:52pm |
I didnt think of that, but wouldnt it be noisy if i held in the clutch? it goes away when i hold the clutch in
'41 Allis B
rpropst
Posted: 30 Oct 2016 at 4:44pm |
If it is a transmission bearing. The top shaft can be removed by removing PTO housing and disconnect torque tube from transmission.
Remove bearing retainer and shift forks. Drive shaft
out the front.
1950 snap coupler B 1948 WD 1951Ca 1952B 1952adjustable axel B
wbecker
Posted: 30 Oct 2016 at 4:46pm |
The through out bearing should be doing nothing with your foot off the clutch pedal.
Sounds like loose transmission main shaft bearings are loose, not at all uncommon. You will need to remove the trans to replace or tighten the bearings. However it could run that way for a long time without hurting anything, in my opinion. Bill B |
DiyDave
Joined: 11 Sep 2009 Location: Gambrills, MD Points: 54698 |
Posted: 30 Oct 2016 at 6:03pm |
Might also be a pilot bearing, making the noise, but I can't remember what the b has. Try this: Shift to N, then step on clutch, if noise goes away when you release clutch, TO bearing is bad, if noise goes away, when you step ON clutch, its the pilot, or tranny brgs...
john2189
Posted: 31 Oct 2016 at 9:43pm |
thanks all but it sounds to be in the trans area,not the bell housing. I guess ill take it apart this winter
'41 Allis B
