D10 Timing and Temp
Jeff K View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jeff K Quote  Post ReplyReply Direct Link To This Post Topic: D10 Timing and Temp
    Posted: 29 Oct 2016 at 8:59pm
I have two issues on my D10 restoration.
1. I set-up the timing per the instructions in the service manual and the tractor seems to run well. I wanted to test the timing so I put a timing light on I cannot see the Fire mark that I am supposed to be seeing. I rotated the distributor both ways to the point that it won't run and still cannot see the mark (which I painted in white to make it most visible). Granted I do not know exactly what 1600 rpm's is but a fast idle should be close. I don't get it.
2. I have a brand new water pump, a brand new temp gauge, brand new radiator and the tractor runs in the red at about 230 degrees. I even took the thermostat out and still it gets up to just over the red mark (220 degrees). I tested the thermostat and it reads a little hot but within about 15 degrees).
You guys have any suggestions or ideas?
Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 29 Oct 2016 at 9:17pm
Which hole are you looking thru?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 29 Oct 2016 at 10:27pm
Adjust ignition timing at FULL wide open throttle.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 30 Oct 2016 at 5:56am
Put an IR thermometer, on various spots on the motor.  The 149 motor has the sending unit right next to the exhaust manifold, its not always accurate.  The IR heat gun can find hot spots.  Sometimes  there can be mineral deposits, inside the block, causing poor coolant flow...
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 30 Oct 2016 at 6:21am
Was the engine tore down and block cleaned?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jeff K Quote  Post ReplyReply Direct Link To This Post Posted: 30 Oct 2016 at 7:30am
I am looking through the right hole (left side center). I will try timing at full open throttle. Is there a way to test water flow?
How's this for an idea? If I drill a small hole in a rubber cork and place that in the hole where the heat sensor goes and then put my wife's digital cooking thermometer in there wouldn't that be a good test to the actual temperature?
Jeff
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 30 Oct 2016 at 8:00am
Jeff,
 Try taking the temp gage probe out and testing in a pan of boiling water with a known accurate thermometer beside and see if it reads ok?
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 30 Oct 2016 at 9:27am
If the timing is off, it can cause the engine to run hot.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jeff K Quote  Post ReplyReply Direct Link To This Post Posted: 30 Oct 2016 at 1:41pm
The timing was indeed off. I think I am a whole gear tooth off. I spun the distributor about 15 degrees c-clockwise and the fire line showed up and now it runs cool.
Thanks guys :)
Jeff
