D17 hydraulic problem
JarrodACFan View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JarrodACFan Quote  Post ReplyReply Direct Link To This Post Topic: D17 hydraulic problem
    Posted: 27 Oct 2016 at 9:13pm
We have a D17 Series 4 and have been having some hydraulic problems lately. The tractor has a fully hydraulic loader on it, ran off of the rear remotes. About a month ago, the loader sort of jerked when it was going up, and we thought it was just a plugged filter, so we replaced the spin-on filter. After that, we didn't use it until today when we got ready to put it on the grain auger to fill the bin. We unhooked the bucket tilt and hooked up the cylinder on the auger. It started jerking again, like it had before. This time, it wouldn't even lift the auger up enough to get over the bin. It sounds like the pump just is spinning not doing anything, then all of a sudden it starts pumping for a few seconds, then quits again. What could be our problem? It does the same thing with either remote.
1956 WD45 Narrow Front Factory Power Steering, 1953 WD Wide Front
Allis Express in Muncie, IN
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 27 Oct 2016 at 9:18pm
Low on hydraulic oil. Dipstick to the left of the gearshift. Engine off for 10 minutes and oil should be half-way up on the dipstick.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 27 Oct 2016 at 9:37pm
Yep, that's the way they act when they get low on oil.     MACK
Lynn Marshall View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lynn Marshall Quote  Post ReplyReply Direct Link To This Post Posted: 27 Oct 2016 at 9:53pm
If the oil level is good, it could be the relief valve cartridge.
Farmuse01 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Farmuse01 Quote  Post ReplyReply Direct Link To This Post Posted: 28 Oct 2016 at 12:16pm
Just a quick and cheap thought..the remote couplers on your tractor and possibly your loader just wore out? Only asking because when dad bought his series IV the round baler cylinders would jerk until he replace the couplers. We just guessed and it worked for us. We just thought afterwards that the oil couldn't flow through them. Hope that make sense! Again just a thought!
Jonathan
Post Options Post Options   Thanks (0) Thanks(0)   Quote JarrodACFan Quote  Post ReplyReply Direct Link To This Post Posted: 28 Oct 2016 at 10:34pm
Ok, well I feel dumb... I thought I checked the oil the other day, but I guess I didn't... Grandpa added some to it today, but we didn't have time to use it any to test things. Farmuse01, that is a good thought. That will be one of the first things I check if the additional oil doesn't do the trick.
Don(MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 29 Oct 2016 at 9:55am
I had a D17 Series 4 come in the shop last year with the same trouble it turned out to be the suction line hose was sucking air and it didn't leak oil with the engine off, changed  the hose and she lifted just fine.
Post Options Post Options   Thanks (0) Thanks(0)   Quote JarrodACFan Quote  Post ReplyReply Direct Link To This Post Posted: 30 Oct 2016 at 12:46pm
Well, we filled the oil up and it still does it. I am fairly confident the couplers aren't the problem because you can hear the pump kick in and out for lack of a better term. Don, your air idea is a good possibility, I will have to look into that. Where exactly is this hose? I assume from the bottom of the tractor to the suction side of the pump?
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 30 Oct 2016 at 9:19pm
Does it work ok at idle?    MACK
