Pull Type Disc ID |
CrestonM
Joined: 08 Sep 2014 Location: Oklahoma Points: 8459 |
Topic: Pull Type Disc IDPosted: 26 Oct 2016 at 4:59pm |
I just obligated to buy this 7' drag disk. It's the kind that you straighten the gangs for road transport. It looks like an Allis, but does anyone know for sure? And if so, what model?
Thanks! ![]() ![]() ![]() ![]() |
CTuckerNWIL
Joined: 11 Sep 2009 Location: NW Illinois Points: 22825 |
Posted: 26 Oct 2016 at 5:14pm |
I have the same disc if it's 6 foot. I thought it was called a #10 ? Those frames that the weights are on are perfect for setting 2 cement blocks in.
CrestonM
Posted: 26 Oct 2016 at 5:28pm |
Thanks Charlie!
cement blocks...like cinder blocks? If so...why just 2?
Edited by CrestonM - 26 Oct 2016 at 5:29pm |
Auntwayne
Joined: 23 Apr 2011 Location: Edwardsville Il Points: 1589 |
Posted: 26 Oct 2016 at 9:00pm |
You need to figure out what the tractor weights belong to. Might be able to make a few bucks ? Free disc ?
Dad always said," If you have one boy, you have a man. If you have two boys, you have two boys". "ALLIS EXPRESS"
CrestonM
Posted: 26 Oct 2016 at 9:20pm |
The weights aren't included.
Ray54
Joined: 22 Nov 2009 Location: Paso Robles, Ca Points: 4792 |
Posted: 26 Oct 2016 at 9:26pm |
Now that it is ID take the pictures down you have some green parts there and you don't want it PINK some morning.
The solid rounds with the T on the back are 100 lb weights from JD 36 pull harvester.Counter weight for the header lift,before hydraulics and a 20 foot head has some weight to it. It would cut with the JD95 or a Gleaner C. But to make green haters happy JD did not design it they bought rights from Caterpillar in the 30's. Was a Holt design from the teens.JD did sell them until in the 50's when they had the 95 to replace it. Disc looks to be in good shape not bent and welded. |
CrestonM
Posted: 26 Oct 2016 at 9:58pm |
Learn something everyday! Good thing the weights aren't mine lol
dawntreader74
Posted: 26 Oct 2016 at 11:37pm |
that type of hitch same as one i have MM or oliver
CTuckerNWIL
Posted: 27 Oct 2016 at 4:16am |
On mine, 2 fit nice on each gang. That is 8 blocks total. |
Allis dave
Joined: 10 May 2012 Location: Northern IN Points: 3085 |
Posted: 27 Oct 2016 at 6:55am |
It's an Allis disk. I have a manual for one at home. I'd have to dig it out and see what the model is.
CrestonM
Posted: 27 Oct 2016 at 7:55am |
Thanks guys! Looks like it will be a great match for my WC!
CALEBnOK
Posted: 27 Oct 2016 at 9:30am |
The weights are off my #34 holt combine. Wheel weights are off a moline we had
RMD
Joined: 07 Oct 2009 Location: Connecticut Points: 304 |
Posted: 27 Oct 2016 at 9:45am |
Doesn't look like the 6 ft. tandem AC disk that we had which I thought was a No. 10. Hitch and adjusting mechanism are quite different.
Ray54
Posted: 27 Oct 2016 at 10:49am |
The mind is going as fast as the body is. They only weigh 50 lbs on the Holt36 and think the 34 is the same. Just feel like 100 now with my old body. I'm sure Creston dose not have this problem. I can supply some nice limestone rocks to weight your new disc. You roll into my tractor bucket and I will deposit in your truck(carefully) for free. |
Brian F(IL)
Joined: 14 Sep 2009 Location: Paxton, IL Points: 2724 |
Posted: 27 Oct 2016 at 11:42am |
It's not a #10. Rear hitch and angle adjustment is different. I'll have to look in one of my old books to see if I can find a picture and correct model number.
TedBuiskerN.IL.
Joined: 11 Sep 2009 Location: Davis, IL. Points: 1959 |
Posted: 28 Oct 2016 at 10:15am |
According to my book, it's a #9 tandem disc. I have three in the barn, six, seven, and eight foot. All for sale.
CALEBnOK
Posted: 28 Oct 2016 at 5:37pm |
I put it in road position and the rear gang is 8ft 6" wide.
