WD 45 lift cyl snap ring |
HD6GTOM
Topic: WD 45 lift cyl snap ringPosted: 25 Oct 2016 at 9:51pm |
Guys, how do you get this darn thing back on the end of the cyl shaft? We did not take it off, found it in the cylinder when we took it apart. There is no way to get snap ring pliers on it. Thanks Much. Tom
MACK
Posted: 25 Oct 2016 at 10:12pm |
Spread it with one pair of snapring pliers enough to get another into ends. MACK
HD6GTOM
Posted: 26 Oct 2016 at 8:02am |
Thanks MACK tried that but there is no way to get a pair of snap ring pliers on the ends of the ring. Cut sorta like this on the ends with no hole to put pliers into ~.
DrAllis
Posted: 26 Oct 2016 at 8:39am |
If that is the round wire type of ring, you might be able to sharpen it a bit to use flat tanged pliers.
HD6GTOM
Posted: 28 Oct 2016 at 9:11pm |
Found a pair of retaining ring pliers used to rebuild auto tranny's, should have it on right after work tomorrow.
