Dr. Allis, update on the L3 |
bakwoodsfarm
Joined: 02 Sep 2010 Location: Woodleaf,NC Points: 511 |
Topic: Dr. Allis, update on the L3Posted: 25 Oct 2016 at 6:38pm |
I have bought the 25 tooth sprocket (71132389). That thing was $89 at Agco. Now that I have it, how do I put it on? It is for a keyed shaft bigger than the one on the beater. And has no holes for the slip clutch.
Thanks,Brad |
CrestonM
Joined: 08 Sep 2014 Location: Oklahoma Points: 8459 |
Posted: 25 Oct 2016 at 6:52pm |
Shims around the shaft and a welder?
Lol, no, don't do that. The Dr will have a proper solution! Maybe you got the wrong one?
tbran
Joined: 14 Sep 2009 Location: Paris Tn Points: 3546 |
Posted: 25 Oct 2016 at 9:19pm |
IT GOES ON THE CYLINDER GUDGEON ON THE RH SIDE IT DRIVES TO BEATER FASTER THAT THE 18 TOOTH SPKT
Adam Stratton
Posted: 25 Oct 2016 at 9:44pm |
Should be a big nut you loosen and then it is a keyed shaft. It is on your right when looking from the front.
SteveM C/IL
Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8734 |
Posted: 26 Oct 2016 at 8:21am |
DrAllis
Posted: 26 Oct 2016 at 8:45am |
If you're going to be switching it back and forth between beans and wheat, use anti-seize when installing the sprocket and make a roller chain extension, because the chain will need a few extra links to fit the 25 tooth versus the 18 tooth.
Lonn
Joined: 16 Sep 2009 Location: Назарово,Russia Points: 29817 |
Posted: 26 Oct 2016 at 9:01am |
Right and left is always as you are seated in the seat. The tailings return is on the right. The sprocket you want is on the left if I am looking at the sprocket we are talking about
Wink I am a Russian Bot |
bakwoodsfarm
Posted: 26 Oct 2016 at 12:02pm |
it has no holes for the slip clutch in the sprocket, the hole in the sprocket is keyed and the hole is quite a bit bigger then the shaft.
DrAllis
Posted: 26 Oct 2016 at 12:07pm |
The 25 tooth speed-up sprocket goes on the ladder side of the throat on the cylinder shaft, not the beater shaft.
bakwoodsfarm
Posted: 26 Oct 2016 at 7:13pm |
That makes sense now, thanks Doc
