hd5 water pump
sdees View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote sdees Quote  Post ReplyReply Direct Link To This Post Topic: hd5 water pump
    Posted: 25 Oct 2016 at 11:12am
Does anyone know what the GPM is on the hd5/Detroit 2-71? Has anyone replaced with an inline 12v water pump?
CAL(KS) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 25 Oct 2016 at 11:41am
nut sure why you would want to.  gm parts still easily obtainable
Post Options Post Options   Thanks (0) Thanks(0)   Quote sdees Quote  Post ReplyReply Direct Link To This Post Posted: 25 Oct 2016 at 11:49am
I cannot find a water pump for under 800$ for the 2-71
gemdozer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote gemdozer Quote  Post ReplyReply Direct Link To This Post Posted: 25 Oct 2016 at 3:04pm
I should have for a hd5  1 or 2 wather on racking
Post Options Post Options   Thanks (0) Thanks(0)   Quote sdees Quote  Post ReplyReply Direct Link To This Post Posted: 25 Oct 2016 at 9:58pm
How much would you let one go for?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 26 Oct 2016 at 8:50am
Once arrived as a spare you should take a used pump to your servicing Detroit Dealer and have them install new bearings and seals, inspect the impeller and set the tolerances, when swap it on the engine then do the same with your old pump and spare it on shelf.  Bearings and seals are least costly, it is getting decent core housings and impellers that are not any longer made that drives the prices.
Post Options Post Options   Thanks (0) Thanks(0)   Quote sdees Quote  Post ReplyReply Direct Link To This Post Posted: 26 Oct 2016 at 10:12am
dmiller I agree , biggest problem is mine was destroyed by the pervious owner.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 26 Oct 2016 at 11:40am
Sorry, get at least a used one to build will be OK
This page was generated in 0.352 seconds.
