Getting a acurate pulling weight?
Ken in Texas View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ken in Texas Quote  Post ReplyReply Direct Link To This Post Topic: Getting a acurate pulling weight?
    Posted: 24 Oct 2016 at 5:27pm
Our club scales that weigh the whole tractor began to have accuracy problems right from the git go at last springs show and pull. We were asked to go on with the pull using the honor system being most pullers know what class they are weighted to pull in without going over a scale.
Well, here it is time again for the BIGGIE. The LA State Fair pull in Shreveport this Friday and Saturday. The estimated cost to REPAIR &
recalibrate the club scale was close to 5 grand and was not in the budget anytime soon.
So. A north LA club is bringing their scale to Shreveport so we have a scale. A small scale where you weigh the front axle first then the rear axle and add the two readings together and by some vodo math get a accurate gross pulling weight for all tractors coming across the scales.
Tell me what you know about weighing the front and the rear and adding them up as far as accuracy goes across the board for tractors weighing #3000 up to #12000
Edited by Ken in Texas - 26 Oct 2016 at 9:10am
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 24 Oct 2016 at 5:56pm
It works for the state police, when they catch you on the side of the hwy...Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 24 Oct 2016 at 6:48pm
Wow! That sounds like a lot to get the scales re calibrated?
Dans 7080 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dans 7080 Quote  Post ReplyReply Direct Link To This Post Posted: 24 Oct 2016 at 9:09pm
I've been going through this at work. Think of it this way. If you weigh 200lbs and stand on two scales one leg on each one. You might have 90lbs on one leg and 110lbs on the other. Either way itl total 200lbs. Split weighing works. Although hard to explain at times its a simple concept. If it didn't work how can DOT weigh a semi on 10 seperate scales and get an accurate weight.
Allis dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis dave Quote  Post ReplyReply Direct Link To This Post Posted: 25 Oct 2016 at 6:49am
Scales are expensive. A new semi truck scale is about $70k
Charlie175 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 25 Oct 2016 at 7:10am
All I know is that pulls at different locations never weigh the same. Some vary by 300 lbs.
Charlie
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ken in Texas Quote  Post ReplyReply Direct Link To This Post Posted: 26 Oct 2016 at 9:06am
Guys.
What the DOT is interested in is overloading a axle beyond its rated capacity not the gross weight of the entire truck and contents.
I played with my bathroom scale that weighs me at 202.4.
Laying out flat facing down with both hands on the scale toes on the floor I have 120.8. Toes on the scale hands on the ground 51.4. Added together that is 172.2. So much for weighing myself top half and bottom half separate and getting close to a correct total. VODO Math
   When our clubs whole tractor scale was working my weight matched my weight on a certified scale ticket
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 26 Oct 2016 at 10:16am
I have much experience of the roadside D.O.T. Scales. what they're counting on is to not dispute what they weigh you at. I have beaten the roadside ticket many times but either having a certified weigh ticket either when I've loaded or shortly after getting stopped. and showing that to the judge. The few times when I'd known they were hitting hard in the area and gotten the certified ticked earlier, I never mentioned this to the officers writing the ticket. When asked by the judge why I didn't show this to the officers at the scene, my reply was they only wanted to see the shippers B/L. They really turned beet red when the found out I knew I was legal to begin with. It didn't take too long for them to leave me alone after having to show up in court  a few times, only to have the judge throw out the tickets.
    So the short answer is split weighing only kinda works.   To be anywhere near correct everything must be on a level surface, with not difference in the tops of the different scales.
   Ken; Try standing with one foot each on two identical scales that are calibrated identical.
WF owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 26 Oct 2016 at 10:56am
The nice thing about split weighing is it's easy to see how much moving weights around effects front / rear end weight. I was shocked to see how much placing the weights behind the rear wheels (instead of placing them just ahead) changed the front end weight.
Tbone95 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 26 Oct 2016 at 11:26am
As long as the tractor remains level between the weighings, it's perfectly accurate. Ken's bathroom scale example is not level weighing and not the best scale in the world.
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 26 Oct 2016 at 4:20pm
A person or animal can shift their weight from one foot to another on a scale. A vehicle does not have that ability.
cwhit View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cwhit Quote  Post ReplyReply Direct Link To This Post Posted: 26 Oct 2016 at 6:48pm
As long as ALL pullers use the same scale, then it's about as accurate as you can get.
bradley6874 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bradley6874 Quote  Post ReplyReply Direct Link To This Post Posted: 26 Oct 2016 at 7:26pm
I weigh mine seperate front and combined all the time keep track percentages front to rear and total all the time   most of the time it dosent add up I think its due to scale height the higher they are from ground level the farther they are off if your worried about it take a regular (non pulling tractor) take it to a certified scale and weight it then take it to the pull weigh it there and adjust classes to suit keep the tractor around an check the scale periodically durring the pull like stated if every body uses the same scale who cares you are all the same weight
Brampton 02 gt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brampton 02 gt Quote  Post ReplyReply Direct Link To This Post Posted: 26 Oct 2016 at 8:48pm
I have found that these scales were not that accurate as I added more weight to the rear the front got lighter and when they did the calc I wasn't getting heavier according to the math.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ken in Texas Quote  Post ReplyReply Direct Link To This Post Posted: 27 Oct 2016 at 1:54pm
I finally got my CA's weight and balance set to work well in 3500, 4000 and 4500 just by adding 500 lbs of suitcases to 3500 and another 500 lbs to 4000. This was worked out by weighing the whole tractor.
No telling now what the calculated weight will be weighing front and rear axles separate. The CALCULATED weight is the class you pull in along with everybody else. If my calculated weight adds up to 3300 I need 200 more pounds someplace where it will do the most good to be competitive in 3500
Edited by Ken in Texas - 27 Oct 2016 at 1:57pm
This page was generated in 0.087 seconds.
