Gleaner Auger height |
nick121
Topic: Gleaner Auger heightPosted: 22 Oct 2016 at 8:18pm |
Hi, Just wondering If the auger needs to be fully extended to unload? It is tall enough for a 200 bushel wagon all the way extended but I bought a 400 bushel wagon and It is pretty tall. If I retract the auger it has a higher reach but Im not sure if It is meant to do that?
It is a hydraulic fold auger. Thanks in advance Nick
victoryallis
Joined: 15 Apr 2010 Location: Ludington mi Points: 2878 |
Posted: 22 Oct 2016 at 8:35pm |
If positioned perfectly a K could dump into our 350 bushel wagons.
bakwoodsfarm
Joined: 02 Sep 2010 Location: Woodleaf,NC Points: 511 |
Posted: 22 Oct 2016 at 8:37pm |
Take an 1 1/2" pipe and cut it 1 1/2" long, then cut it in half length ways. Use a hose clamp to put it back together on the unload auger cylinder. This will give you about another foot of unload height. Won't hurt anything.
rrhead(SD)
Joined: 11 Sep 2009 Location: Canton, SD Points: 432 |
Posted: 22 Oct 2016 at 8:50pm |
I did the pipe on the cylinder. It raised the end of auger at least 12 inches. I can now unload without hitting my nephew's trailers. rrhead(SD)
2 WDs,WD45,D-14,D-17,D-19D,180,7020,6080FWA,6080 2wd, 6080 2wd(cab),8050FWA,8550,4W-305,Massey 8250. Gleaner L3, R62 &R65 Agco-Allis 1616H & 1920H, AC 720, Terra-Tiger
MACK
Posted: 22 Oct 2016 at 8:54pm |
If you don't want to replace the ujoint, better extend all the way. If the ujoint clatters at all, it won't long. MACK
SteveM C/IL
Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8684 |
Posted: 23 Oct 2016 at 12:54pm |
My F2 has a stop on back side of swivel.I added a new one a little short of original.Raised it about 6in.Just clears the bows on my hopper bottom if both are on flat ground.I almost never unload full throttle,usually 1/2-2/3.
AC7060IL
Joined: 19 Aug 2012 Location: central IL Points: 3580 |
Posted: 23 Oct 2016 at 8:33pm |
Make sure to keep auger u-joint at pivot well greased.
jason82
Posted: 23 Oct 2016 at 10:03pm |
I just posted this of our F2, shows dumping into a tempie grain trailer.
Gleaner F2 Edited by jason82 - 23 Oct 2016 at 10:04pm |
Adam Stratton
Posted: 23 Oct 2016 at 10:34pm |
What model did the pipe on the cylinder trick work on? I would like to get some more height on our l series combines but either don't understand the trick or don't think it would work on an l
shameless (ne)
Joined: 08 Jul 2016 Location: nebraska Points: 7463 |
Posted: 24 Oct 2016 at 5:03am |
when I needed extra height for my "K", when dumping into the semi, I had 2- 2x12's nailed together about 2 ft long. layed it on the ground and drove up on it with the left drive wheel. worked well!
nick121
Posted: 24 Oct 2016 at 5:38am |
Okay, I should be good then, It just looked low when I was dumping in the small wagon. Maybe my depth perception isn't too good. lol. I wont find out for a few days until this rainy weather stops so I can finish my beans.
Jason 82: Nice soybeans, I wish mine were running 65 bushel an acre. How many acres do you run through that combine?
Jordan(OH)
Joined: 11 Sep 2009 Location: Celina, OH Points: 1569 |
Posted: 24 Oct 2016 at 6:37am |
What is your 400 bushel wagon? We used to dump in J&M 385s with an F3. Picked the auger up some never hurt anything.
nick121
Posted: 24 Oct 2016 at 8:07am |
It is a used bruns wagon. They are made here in Ontario
ILGLEANER
Joined: 13 Sep 2009 Location: Willow Hill,ILL Points: 6448 |
Posted: 24 Oct 2016 at 9:10pm |
If we didn't do that on our L3s we would never get them dumped. If you raise it to high it should shut off.
SteveM C/IL
Posted: 24 Oct 2016 at 11:33pm |
Them L's got electronics.The F2's until the latest were manual and you can fold the auger in while its running....it won't still be running if you get it folded LOL! |
