Tough old 180
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Topic: Tough old 180
    Posted: 17 Oct 2016 at 8:21pm
Well been working the crap out of my 180, setting fence corner post holes, grading rain cuts in the drive and moving materials but my luck is shortening as I smelled coolant and saw the heat coming up.  Got it to the barn and shut down either radiator or water pump and or both leaking.  Friday get to tie into that.
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 17 Oct 2016 at 8:46pm
Might as well check everything else out while you are at it:  replace thermostat and rad hoses (if needed).  She'll be as good as new when you are done.
