My New Favorite Tool!
 Rating: Topic Rating: 1 Votes, Average 4.00  Topic Search Topic Search  Topic Options Topic Options
Dave(inMA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave(inMA) Quote  Post ReplyReply Direct Link To This Post Topic: My New Favorite Tool!
    Posted: 15 Oct 2016 at 7:56am
Decided to finally replace the steering wheel on the WD45 as the old one is badly deteriorated. With a replacement and a brother to help in hand, we went at it. Drilled the pin and applied hammer and drift pin. No joy. Tried heat. No joy. Getting the old one off wasn't going well when he asked if I had an air hammer in the shop. After some discussion and research, we acquired one.....what a tool! Easily drove out the pin and drove the hub off the shaft. Proving once again that having the right tool on hand is a wonderful thing!
WC, CA, D14, WD45
TramwayGuy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TramwayGuy Quote  Post ReplyReply Direct Link To This Post Posted: 15 Oct 2016 at 9:00am
I had the exact same experience with a large roll pin. 2 seconds with an air chisel with pin attchachment after beating on it for two hours with hammer and pin punch. I could not believe it.
Edited by TramwayGuy - 15 Oct 2016 at 9:00am
CrestonM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 15 Oct 2016 at 9:55am
Grandpa has one, and he likes it. I've never used one.
My favorite tool is my cutting torch. Before it, if I had to heat something and bend it or cut it, I would just wait until I had several things to cut/bend and I would build a fire out back and heat the pieces up that way and shape them with a hammer and anvil.
Now with the flick of a striker I have instant, portable heat! Makes removing badly rusted nuts a breeze!
shameless (ne) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless (ne) Quote  Post ReplyReply Direct Link To This Post Posted: 15 Oct 2016 at 10:02am
I bought one when I had to go thru my basement wall to replace an elbow in the sewer line, just bought a cheapy HF one as I've really never needed one before and didn't wanna spend a lot, cuz I prolly wouldn't need one again. and you are right, that this is the bestest buddy! I still haven't used it again, but prolly will when I start dismantling combines!
Dans 7080 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dans 7080 Quote  Post ReplyReply Direct Link To This Post Posted: 15 Oct 2016 at 6:17pm
An air chisel will work wonders.
