Dual Hydraulic Outlets
rustyorange45 View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote rustyorange45 Quote  Post ReplyReply Direct Link To This Post Topic: Dual Hydraulic Outlets
    Posted: 14 Oct 2016 at 8:31am
I just finished installing a 3 way hydraulic ball valve on my WD45. It allows me to raise my loader and valve it off and then I can use the lift cylinder for my mower . Really easy and I don't have to take my loader off when I use an implement with hydraulic lift. Use a 1/2" NPT 3 way ball valve, one 1/2" NPT nipple, two 1/2" NPT male 90*, and two hydraulic couplers. Plumb it into outlet of transport valve. Saves a lot of time and aggravation. Thanks to all who gave advice on this proje
1953 WD45 WF/Model 90 Loader, Oxnard Rear Blade, 80R Mower, Model 209 Disc, WD Rear Mounted Scoop, Model 184 & 160 Rotary Mowers, 1952 CA NF/L306CA mower, 1953 CA WF/Model 8 Loader.
AaronSEIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AaronSEIA Quote  Post ReplyReply Direct Link To This Post Posted: 14 Oct 2016 at 12:12pm
Sounds good as long as everything you used is built to handle the 3500 psi or so of the stock pump.
AaronSEIA
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote rustyorange45 Quote  Post ReplyReply Direct Link To This Post Posted: 14 Oct 2016 at 3:09pm
Everything is plumbed with hydraulic fittings.
