2600 disc - c shank repair (pic)
Ron(AB) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ron(AB) Quote  Post ReplyReply Direct Link To This Post Topic: 2600 disc - c shank repair (pic)
    Posted: 12 Oct 2016 at 9:07pm
What do you think of this repair?
Its not mine, so you can say freely.
Dans 7080 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dans 7080 Quote  Post ReplyReply Direct Link To This Post Posted: 12 Oct 2016 at 9:29pm
If it works go for it! I myself wouldn't trust welding it like that. If that's spring steel for the flex it will break at the weld before too long.
shameless (ne) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless (ne) Quote  Post ReplyReply Direct Link To This Post Posted: 12 Oct 2016 at 10:52pm
looks like an old weld, must be working. I do agree with Dan about the spring part, but I have also seen where welding improves where a defect was. if the disk is cheap enough, go for it! also that may be a bargaining tool!
Amos View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Amos Quote  Post ReplyReply Direct Link To This Post Posted: 13 Oct 2016 at 6:10am
I wonder what happened to cause them to be broke to need welding in the first place??
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless (ne) Quote  Post ReplyReply Direct Link To This Post Posted: 13 Oct 2016 at 7:06am
could have been edge of field hazards or forcing it into terraces? or poor design?
Allis dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis dave Quote  Post ReplyReply Direct Link To This Post Posted: 13 Oct 2016 at 7:42am
It's supposed to be a spring that "gives a little" and makes hitting rocks and cause a little less damage. That looks like a VT which are very heavy and would be too hard to break hitting a big rock going 8mph.
I wouldn't like that repair because I'd think it would take away the designed spring action. I would replace it instead if I could afford it.
JPG AUSTRALIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JPG AUSTRALIA Quote  Post ReplyReply Direct Link To This Post Posted: 13 Oct 2016 at 8:01am
Why is an allis disk green?
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 13 Oct 2016 at 8:50am
That is Kraut green
Tbone95 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 13 Oct 2016 at 8:58am
At first I didn't notice there were 2 of them fixed like that.
Well, like all repairs like that, it will work right up until it doesn't. I think it would spring and give just fine, but it will fatigue that repair steel more quickly I would think.
Post Options Post Options   Thanks (0) Thanks(0)   Quote JPG AUSTRALIA Quote  Post ReplyReply Direct Link To This Post Posted: 13 Oct 2016 at 9:19am
That makes sense now you say that,they only where ever orange here.
IBWD MIke View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 13 Oct 2016 at 11:13am
Apparently that guy doesn't have my luck! I would not weld a spring and expect it to last.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ron(AB) Quote  Post ReplyReply Direct Link To This Post Posted: 13 Oct 2016 at 1:18pm
Its a first time for me to see something like that… I cant't imagine what he hit to break two shanks?
Its a 22 ft single fold disc, rebadged deutz/allis.
Probably, new shanks are not available and the guy had to get her done.
LeonR2013 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LeonR2013 Quote  Post ReplyReply Direct Link To This Post Posted: 13 Oct 2016 at 1:45pm
There is a rod for welding spring steel that works pretty good. If that was used on the shank, then plated I don't see why it wouldn't work good. But if you get it too stiff it will break again.
BlackFatbob View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BlackFatbob Quote  Post ReplyReply Direct Link To This Post Posted: 13 Oct 2016 at 2:46pm
I'm thinking sistering plates left and right would be stronger than fore and aft.
This page was generated in 0.176 seconds.
