15 inch wheels/rims
rvschmitz View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rvschmitz Quote  Post ReplyReply Direct Link To This Post Topic: 15 inch wheels/rims
    Posted: 12 Oct 2016 at 8:04pm
Wanted:  2 15 inch wheels/rims to mount Firstone 15 inch 5.00x15 rake type(lug tread) on a restored A-C model hay rake. R.V. Schmitz  Atlantic,Iowa 262-716-5250
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 12 Oct 2016 at 9:39pm
What is the bolt pattern and how many holes? I have two small rims, will have to check bolt pattern. They are same as new.     MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 12 Oct 2016 at 10:21pm
If you don't mind. Where did you find the tires at? I would like a set also if possible. Thanks Tracy
R Aiken View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote R Aiken Quote  Post ReplyReply Direct Link To This Post Posted: 13 Oct 2016 at 7:30am
I have a few wheels that size with a 4 bolt pattern. They were on Yocum sprayer booms. I also have some 6,xx 15 tires and whells off JD 494 planters. They will fit most hay rakes that take 4 bolt wheels.
Allis dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis dave Quote  Post ReplyReply Direct Link To This Post Posted: 13 Oct 2016 at 7:44am
I thought most of those 4 bolt rims were just a standard ag size. Probably can be found at Shoups or a local ag tire dealer for about $50
HD6GTOM View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote HD6GTOM Quote  Post ReplyReply Direct Link To This Post Posted: 13 Oct 2016 at 8:00am
Tracy I just checked with 2 of my old suppliers, they have those tires in stock in another brand. Any Farm tire supplier in your neck of the woods should be able to get them for you.
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 13 Oct 2016 at 8:01am
Can be found at Baum Hydraulics also. http://www.baumhydraulics.com and at shoup parts and other places. http://www.shoupparts.com Be sure to look at the offset required.
Gerald J.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 13 Oct 2016 at 6:11pm
Miller tire also has the rake tires.  About $75 per, last time I bought them...
Post Options Post Options   Thanks (0) Thanks(0)   Quote rvschmitz Quote  Post ReplyReply Direct Link To This Post Posted: 13 Oct 2016 at 8:42pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote rvschmitz Quote  Post ReplyReply Direct Link To This Post Posted: 13 Oct 2016 at 8:43pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 13 Oct 2016 at 8:57pm
Tom, Thanks I will try them. Tracy
Post Options Post Options   Thanks (0) Thanks(0)   Quote rvschmitz Quote  Post ReplyReply Direct Link To This Post Posted: 13 Oct 2016 at 9:04pm
The  bolt pattern for the 15inch wheels/rims for a model 78 A-C  (also model 77g) hay rake is 6 hole--can also be 12 hole depending on the wheel hub (can put duals on these rakes as shown in operators/parts books with 12 hole hubs and wheels/rims. (have  a model 78 rake with factory duals --has 12hole hubs and wheels/rims.  Also, my local tire dealer got the 5.00x15 firestone tires from a source in DesMoines, Ia.  Will check on name of supplier.RV.Schmitz  262-716-5250 Note: These wheels/rims can only be 4 to 4.5 inches wide to mount this size tire. Note : A-C never used 4 bolt wheels/hubs on these rakes.
