Gleaner m2 feeder beater removal
Sandknob View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sandknob Quote  Post ReplyReply Direct Link To This Post Topic: Gleaner m2 feeder beater removal
    Posted: 09 Oct 2016 at 11:20pm
OK guys/gals I had a couple fingers on my feeder beater on the m2 come out of the guides and jam up inside the beater. After a couple hours of work I am down to one large bearing on the left side (standing in front of combine looking at it) and it's associated shaft and the shaft and inner bearing on the right side (adjustment plate (for finger setting) is already removed from the right side. I am at a loss for removing the beater from the machine now. What is my next step?
I figured I would need new fingers, finger holders (looks like the bushings are long gone), slip clutch parts and new adjustment plate on right side. Hopefully Agco has it all.
Thanks in advance for any information anyone has.
Adam
Post Options Post Options   Thanks (1) Thanks(1)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 10 Oct 2016 at 7:16am
The first thing you do is remove all fingers.
Cut the bearing, remove bearing plate, remove six bolts holding shaft in and remove shaft. MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sandknob Quote  Post ReplyReply Direct Link To This Post Posted: 10 Oct 2016 at 7:21am
Cut the bearing? Torch it off I'm assuming? The big bearing on the left side?
VAfarmboy View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote VAfarmboy Quote  Post ReplyReply Direct Link To This Post Posted: 10 Oct 2016 at 8:00am
Adam
If AGCO doesn't have the parts Oakley Combine in Oxford, NC probably does.  Not sure if AGCO still stocks parts for M2s or not but I have had no luck finding parts for my K at the AGCO dealer.
shameless (ne) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless (ne) Quote  Post ReplyReply Direct Link To This Post Posted: 10 Oct 2016 at 9:26am
I think it can only come out one way, think the shaft is longer on one side than the other. I've never had to take one out before
Lynn Marshall View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lynn Marshall Quote  Post ReplyReply Direct Link To This Post Posted: 10 Oct 2016 at 12:08pm
Do as Mack says on what you call the left side. Cut (torch) that bearing,and then just unbolt the stub (drive) shaft. On what you call the right side,go through the inspection hole and remove the half inch bolt that holds that stub shaft into the rectangular block. Take out the three bolts that hold the bearing flanges to the end of the drum. I use a slide hammer to then pull that stub shaft with bearing out.
allisguy.11 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote allisguy.11 Quote  Post ReplyReply Direct Link To This Post Posted: 10 Oct 2016 at 12:54pm
watch that you don't loose fingers. its miserable
Post Options Post Options   Thanks (0) Thanks(0)   Quote allisguy.11 Quote  Post ReplyReply Direct Link To This Post Posted: 10 Oct 2016 at 12:55pm
and I mean the ones on your hand. not the ones in the drum
