Model B cam bearing holes
00transamnh View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 00transamnh Quote  Post ReplyReply Direct Link To This Post Topic: Model B cam bearing holes
    Posted: 09 Oct 2016 at 2:36pm
Hey folks,
I have a 1940 Model b that I am rebuilding the engine on and need some expertise. I have new cam bearings installed in the block and when in position the oil holes between the block and cam bearings do not line up. Approximately 1/2 the hole is covered by the bearings at all 3 locations. Is this normal or do I have cam bearings wirh holes that are off location? I assume what is exposed of the oil hole is sufficient for oiling the cam but want to make sure
Post Options Post Options   Thanks (0) Thanks(0)   Quote 00transamnh Quote  Post ReplyReply Direct Link To This Post Posted: 10 Oct 2016 at 9:53am
Bump-engine build on hold. Any experience with this out there?
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 10 Oct 2016 at 10:00am
just run a drill bit in to open up the holes to match the block.
Dick L View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 10 Oct 2016 at 2:42pm
The holes are to oil the main Bearings. They need to be open.
