D19 motor
gary ny View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote gary ny Quote  Post ReplyReply Direct Link To This Post Topic: D19 motor
    Posted: 26 May 2010 at 8:56am
Can you do a D19 gas in fram rebuild or does it have to be split? I have one that has a occasional knock in it and it sounds  when it does happen to almost sound like a rist pin . But I was looking at it and it looks like the pan would be nearly impossable to get out with the A fram from the front end and the bolts near the power steering unit look like you can't get at them.I have to pull a loader off so I can get a better view but it almost looks like the best thing to do is split it.
skipwelte View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote skipwelte Quote  Post ReplyReply Direct Link To This Post Posted: 26 May 2010 at 9:14am
You can do an in frame, take the loader off, radiator and cowl off, roll the front end and steering casting away from the tractor, be carefuell the steering casting doesnt fall off the front end pivot pin.  Then the oil pan can come off.   You can take the front axle out with out the steering casting, but usually the front end with colapse in a pile then ya wonder how in the heck am I gonna get this back on!!!!   HTH  good luck.
BobHnwO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BobHnwO Quote  Post ReplyReply Direct Link To This Post Posted: 26 May 2010 at 11:43am
Skip,I wish I had known about upsetin the front end when I removed it from my D17,lol,I know now!!
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 26 May 2010 at 9:08pm
I recommend pulling the engine since the axle is coming off.  You might as well check everything while you are at it.
