wd trans stuck in gear |
   nothingfancy
   Joined: 06 Oct 2016 Location: Ft. Wayne , IN Points: 7  |
      Quote   Reply
     Topic: wd trans stuck in gearPosted: 07 Oct 2016 at 1:34am  |
   My son has a wd with the straight shifter. It's stuck in gear so I took the shifter tower off of the trans. there are three gears controlled by the shift forks and the two towards the rear slide easily forwards and back. The gear towards the front of the trans will not slide at all? Tried to use a pry bar but no luck? Any thoughts?? Thanks
   nothingfancy
      Quote   Reply
     Posted: 07 Oct 2016 at 1:35am |
   If it matters at all, the gear is all the way towards the front of the trans.
   CTuckerNWIL
   Joined: 11 Sep 2009 Location: NW Illinois Points: 22825  |
      Quote   Reply
     Posted: 07 Oct 2016 at 5:52am |
   There are 5 gears controlled by the shifter. The 2 forks on the left shift forward and back of neutral so each fork has 2 gears. The right side is reverse gear. All 3 forks have to be in the neutral position to install the shift lever.  If the ball on the bottom of the shifter is wore, it can get out of wack again. The ball can be welded up to keep this from happening , but if you make sure you shift SQUARE each time, it may not get jammed up again. Don't try to shift at an angle from second to third. Shift straight up to neutral, over and straight up to 3rd and you may be OK for a while.
  I may have my right and left mixed up, since it's kinda early for me ![]()  |
  Lena 1935 WC12xxx, Willie 1951 CA6xx Dad bought new, 1954WD45 PS, 1960 D17 NF  |
   nothingfancy
      Quote   Reply
     Posted: 07 Oct 2016 at 6:09am |
   I get all of that but that doesn't help out with the gear that wont slide into neutral. is there something like a snap ring or something that may have broken that is keeping the gear from sliding back? Is it possible that the gear has slide too far on the shaft and come off of the splines? I have looked online for a breakdown on the trans but with no luck. Am I wrong to think that the gear should slide forward and back easily on the main shaft?
   MACK
      Quote   Reply
     Posted: 07 Oct 2016 at 6:24am |
   If it is setting on a hill it may have pressure against it. Release  both clutches with brakes set
 should help.      MACK
   nothingfancy
      Quote   Reply
     Posted: 07 Oct 2016 at 8:41pm |
   Tried that with no results. The gear will spin on the main shaft but won't slide?? This weekend I'm going to jack up the rear and try to spin the wheels and maybe that will help?
   DougS
      Quote   Reply
     Posted: 07 Oct 2016 at 9:09pm |
   I'm wondering if there isn't a piece of metal wedged between the gear teeth. Nudging the tractor backwards may free it if so.
   MACK
      Quote   Reply
     Posted: 07 Oct 2016 at 9:53pm |
   I believe the gear you are talking about in the input gear which does not move. When you look in transmission you should see a gear at front, behind it is a gear with a slot for shifting fork, behind it should be a double gear with a slot for a shifting fork. That is all that is on top shaft.       MACK
   nothingfancy
      Quote   Reply
     Posted: 08 Oct 2016 at 3:23pm |
   That being the case, what does the third fork from the shifter do? Maybe I'm really missing something here and it's right under my nose? The front gear does spin but seems to do so independent of the main shaft until you let the clutch out? I will take another look to see if I'm going crazy or not.
   DougS
      Quote   Reply
     Posted: 08 Oct 2016 at 3:50pm |
   The third fork moves the reverse gear.
   MACK
      Quote   Reply
     Posted: 08 Oct 2016 at 9:56pm |
   For 4th gear it couples the single gear with shifter grove to very front gear that you say turns. For 3rd it slides the same gear towards the rear and meshes with a gear on bottom shaft.       MACK
   nothingfancy
      Quote   Reply
     Posted: 11 Oct 2016 at 10:57am |
   Thanks for the help, You were right about the gear. It was the lower gear that had hung up. Lesson learned.
| Forum Jump | Forum Permissions  ![]() You cannot post new topics in this forum You cannot reply to topics in this forum You cannot delete your posts in this forum You cannot edit your posts in this forum You cannot create polls in this forum You cannot vote in polls in this forum  |
